2 members (TBM, Image),
237
78
Topics49,870
Posts837,670
Posts: 40 |
anybody found a rear mesh to fit under the boot between the tail pipes
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
Most of the time people fit a diffuser, cannot recall what car/model it is from though.. I am sure someone else will be along to advise.
Aero 8 GTN #11
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
James BW had one made up from aluminium by a local fabricator and it looks like a factory fit.
James has a Series 1 car but im sure the idea can be adapted,
When he gets up from his afternoon nap after the pub he will be along...
Aero 8 GTN #11
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
Hic !!  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
![[Linked Image]](https://www.tm-img.com/images/2020/09/08/DSC_0064.jpg) Not a great picture, but here's the rear diffuser on my S4 with side pipes. Not sure if it is different size / shape with rear exit exhausts, also on mine it does run quite a long way forward under the boot to smooth off this area. As mentioned above, James's S1 has a very nice ally one he's had made up, there are pictures on here somewhere. With regards to the mesh you ask about Simon, what about matching that found in the wing top vents either side of the bonnet?
David Aero S4
Come on James..get up and let's see your back end !!!
Come on James..get up and let's see your back end !!! Oi you ! I'll have you know I have been busy fitting several outdoor downlighters to the house (and struggling with the wiring diagram; 'smart switch' and photo electric cell !). However, to keep the 'Fitz happy (and because you have complemented my back end before  ) ...... ![[Linked Image]](https://www.tm-img.com/images/2017/09/27/21015704_1671149392909159_6697363751308441735_o.jpg) - as taken at the Factory event (two ? ) years back. Made using CAD (that's Cardboard Aided Design) ,fabricated locally and then powder coated. Obviously for a Series 4 it would need to be much wider as no exhausts.... James
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
So looking at that I think it should be the template for the next CX derivative.
Gangster low. Racing alloys/knock offs Speedster style screen/roof/trim Lamps in mono colours Sidepipes (sorry has to be done even with an IL Turbo 6) Knock off petrol cap (or charging port, who knows??) Slammed as low as can be (damn that sump!) LSD for the backend G force indicator on the central LCD panel for those tail slides and drifting days.
![[Linked Image]](https://www.tm-img.com/images/2020/09/08/DSC_0064.jpg) Not a great picture, but here's the rear diffuser on my S4 with side pipes. Not sure if it is different size / shape with rear exit exhausts, also on mine it does run quite a long way forward under the boot to smooth off this area. As mentioned above, James's S1 has a very nice ally one he's had made up, there are pictures on here somewhere. With regards to the mesh you ask about Simon, what about matching that found in the wing top vents either side of the bonnet? I think that is a pretty awesome picture to be fair! Do you have anymore of the erm "rear" end, be interesting to see it from a few angles..
Aero 8 GTN #11
