0 members (),
262
45
Topics49,860
Posts837,486
Posts: 119 |
Hi folks. As part of my restoration / mod project, I'm going to have to completely rebuild my dash. Now, what everything is going to be wired up to is going to change dramatically, but I'm going to try to keep outward appearances as original as possible. One of the things I've been trying to sort out is what all the switches and buttons do on the original dash setup, so I can try to mimic their layout and operation on the new dash I'll be building. I've checked out a few recommended sites before and haven't really come across anything useful. The car is a '66 Plus 4, if that helps narrow it down any. Also, if the dashes originally had lettering on them for the switches or anything else like that, I'd appreciate seeing images of that so I can try to replicate that appearance on the new setup. Here's what I've got to work with. Along with the central panel, there's that big push-button thing at the top, and a pull-knob kind of thing in the bottom right of the photo which I'm trying to identify. Thanks in advance for any help you can provide!
Posts: 614 Likes: 1
Posts: 614 Likes: 1 |
might be worth putting the post on the brakehorsepower website as a lot of 60's Plus 4 drivers frequent the site: http://www.brakehorsepower.net/phpBB3/John
Morgan 4/4 Sport Competition
Posts: 107 |
The big pushy-thing at the top is the horn button, and the pully-thing is the choke cable. Mervyn Rutter supplied me with a full set about 12 years ago when I restored my similar 1964 +4, and as far as I'm aware, still has everything. He also rebuilt my speedometer when it gave up a few years later. Never cheap, but always reliable and excellent service. Good luck; lovely car!
John Rutherford (1988 +8)
Posts: 14,009 |
I've been looking through John Worrall's/Liz Turner's book "Original Morgan..The Restorers Guide" There's a good shot of a 1968 Plus 4 dash and John's Super Sport which is almost identical. None of the switches appear to be labelled. I always thought that the top "knob" is in fact a dash light which switches on by pulling out. (I've a similar one bought from Holdens Classic Cars which I was going to fit to my 4/4 Sport.) The lower knob.....choke or starter?
I'm sure there's a Plus 4 owner about to put me right!
Posts: 1,647 |
Hi, SVC can supply all of those parts. Here is their website: www.s-v-c.co.uk/index.htmlClick on electrical components, then switches. There are several pages to look through, but they are all there. Cheers, N-M
Jaguar F-Type V6s roadster 2009 Harley Davidson XR1200 1986 Honda VFR750F (RC24)
Posts: 119 |
Sprinty - That site may be useful at the very least for selling off the spare motor I've got sitting around, thanks for the link! Wyndales - Thanks for the heads-up on a potential parts source, those kinds of leads always come in handy! As for the horn button, that'll be kind of a moot point as I'll likely get a new wheel with a horn in the center, but we'll see about that. The choke wouldn't get much use either seeing as the car's getting a transplant from a fuel-injected setup.  NorthernMogMan - Excellent! That site's going to come in handy! As far as the switches and knobs go... I'm kinda guessing the horizontal one is for the turn signals, one of the top ones is for the headlights, and another's for the wipers... though which is which I have no idea.. There's also the white-trimmed push button in the lower left of the panel. I'd have to take a look, but I'm also guessing the two pull knobs at the bottom are for air vents?
Posts: 375 |
Right in the middle below the thick knob and above the control light there appears to be a 12 V socket with two contacts (+ and -) for a handheld spotlight. Landrovers of 1966 had the same socket and there were lamps available with the matching plug. Attention: the +12 V socket is live with the ignition switched off!
Andreas
Andreas
+4
Posts: 167 |
top center=klaxon three switches= L-R wiper, Accessory light (fog or driving), & instr. lights two jacks in the middle are accessory power Green pilot is turn signal indicator left pilot is main beam indicator, then turn signal switch, then generator ind. last row: choke, ign. and light lower left button appears non-standard
choke and light knobs had a white letter "C" & "L" respectively. Pull thingy at photo bottom right is likely a heater switch
'65 +4 four seater
Posts: 119 |
Excellent! You guys have been a tremendous help with this!
I think I'll do a quick photoshop of the this panel and label everything, just so everyone's in agreement as to what the various items do.
Thanks again, guys!
Posts: 676 |
The lower left white button with dark centre is for the washers - same on my 69 4/4
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
