6 members (Dougie, JohnHarris, BLUE+4, ChrisConvertible, Stephen888, JMcL), 243 guests, and 63 robots.
+8Rich 78
Topics49,871
Posts837,677
Rudolf
DavidR Offline OP
Motorway reduction
So there will be a trial of reduced speeds on some motorways to reduce pollution, the plan is for test 5 mile stretches!
David
Aero S4
If it's anything like the M5 they will have to speed the traffic up somehow to achieve this trial laugh2
The link isn't working (missing " : "). Try this one
Motorway Reduction
Regards
Alan
AP08 MOG
They already use the variable speed limit on the M1 to do this in the Sheffield / Doncaster area — most of the time you would be hard pushed to exceed 60 when they apply the lower limit.
Costock, UK
Disco 5
There have been various 'environmental' speed limits about for a while now to test whether this helps with roadside pollution where houses are close to roads .... not seen any conclusions yet .... how long before some bright spark decides having these littered about the road system to the annoyance and inconvenience of drivers, then making EVs exempt from slowing down (why wouldn't you, not like they produce NO2 at point of use) would be a better way of encouraging EV take-up than any amount of Thunbergian moralising smile
Trial?? Do you believe that is a trial? Or a try on.
Beyond any doubt the best way to cut pollution short of leccy cars is to cut traffic jams. So you cut pollution by getting rid of cycle lanes and bus lanes not by building them.
In sunny north Wales there’s a stretch between the end of the M56 and joining the A55 which has recently become a long 50mph zone to reduce pollution. The limit starts at the Wales border and runs for about 4 miles into Wales. It runs through industrial areas with water purification, metal recycling and the Toyota engine manufacturing plant. As a large flat plane at the bottom of the Dee estuary it’s usually windy.
How on Earth the reduced pollution is supposed to stay in that area is a mystery.
We should all drive through the designated areas in 3rd gear!
Will EV's be exempt from this trial limit ? flyingpig rofl
It simply does not work. If you reduce the speed in heavy traffic zones you get a stop-start column of bunched up traffic at peak periods. The increased traffic density, particularly in stop-start conditions, leads inevitably to increased local pollution.
