Topics49,900
Posts838,039
Posts: 14 |
Hi,
Is it safe to charge a roadster via the lighter socket, and not take out the ECU or anything else in the process?
It's a 2010 model btw.
Cheers,
Nigel
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
No - Don't do it!! Wire up a socket direct to the battery with an inline fuse -- you can buy these in Halfrauds or the like. All that is needed is a small hole in the wooden bulkhead to get the wires through to the battery.
The lighter socket in the glovebox is on a fuse with the lights and something else I can't remember and this WILL blow on a charger(I did it on my 2009 Plus4 before I copped on!!) which then leaves you without lights and no charging either!!
Make sure you use a charger which handles the glass mat batteries
Cheers!
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
A battery conditioner would be OK, they only trickle charge
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 14 |
Thanks for the tip re the fuses Robbie. I was just planning on hooking it up to an optimate/accumate 12v trickle charger to stop the battery going flat whilst waiting for summer to arrive
Posts: 521 Likes: 2
Can't see a problem with that, used similar on my BM with no problem
An optimate will be just fine -- I use one on mine. The advantage of a separate socket is that when you are on the move it can power your Sat Nav Ipod or whatever!!
I plug my car in when it goes into the garage even if only overnight
Cheers!
Posts: 167 |
A small solar panel can be plugged into the lighter to keep tghe battery topped-up provided, of course, that the lighter is "hot" when the key is off.
'65 +4 four seater
Posts: 220 |
Posts: 3,727 |
I've been using my CTEK Trickle charger (using the cable provided) via the Glove Box lighter socket constantly for 2 years without any problems on this and over a year on the previous 4/4
Posts: 1,502 |
Ditto, my 2005 4/4 is almost constantly on charge via the lighter socket, using a CTEK 3600. Brilliant, highly recommended, and never any problem with fuses.
Nigel
