9 members (JMcL, IcePack, Julian BB, JohnHarris, John V6, Burgundymog, RichardV6, Vansrv6, bmgermany), 310 guests, and 31 robots.
+8Rich 96
John V6 50
Topics49,899
Posts838,029
#66374 12/08/11 01:56 PM
niglp Offline OP
Hi,
Is it safe to charge a roadster via the lighter socket, and not take out the ECU or anything else in the process?
It's a 2010 model btw.
Cheers,
Nigel
No - Don't do it!! Wire up a socket direct to the battery with an inline fuse -- you can buy these in Halfrauds or the like. All that is needed is a small hole in the wooden bulkhead to get the wires through to the battery.
The lighter socket in the glovebox is on a fuse with the lights and something else I can't remember and this WILL blow on a charger(I did it on my 2009 Plus4 before I copped on!!) which then leaves you without lights and no charging either!!
Make sure you use a charger which handles the glass mat batteries
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
A battery conditioner would be OK, they only trickle charge
Simon
2002 4/4
2021 Audi A1 sport
niglp Offline OP
Thanks for the tip re the fuses Robbie.
I was just planning on hooking it up to an optimate/accumate 12v trickle charger to stop the battery going flat whilst waiting for summer to arrive gloomy
Can't see a problem with that, used similar on my BM with no problem
Simon
2002 4/4
2021 Audi A1 sport
An optimate will be just fine -- I use one on mine. The advantage of a separate socket is that when you are on the move it can power your Sat Nav Ipod or whatever!!
I plug my car in when it goes into the garage even if only overnight
Cheers!
Robbie
211-WX-1433
A small solar panel can be plugged into the lighter to keep tghe battery topped-up provided, of course, that the lighter is "hot" when the key is off.
'65 +4 four seater
Green & Grown Up
Green & Grown Up
I've been using my CTEK Trickle charger (using the cable provided) via the Glove Box lighter socket constantly for 2 years without any problems on this and over a year on the previous 4/4 stars
Ditto, my 2005 4/4 is almost constantly on charge via the lighter socket, using a CTEK 3600. Brilliant, highly recommended, and never any problem with fuses.
Nigel
