10 members (Scrambledsignals, DJC, BigLes, MJF, Jon G4LJW, John07, Clipper, Vansrv6, Mauli, Black Adder),
291
37
Topics48,346
Posts813,049
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Belle makes a very quiet ticking noise when the indicators are on. I now find I can miss that the inidcators haven't self cancelled occasionally. The repeater lights on the dash are often hard to see if the sun is behind you. Has anyone fitted any kind of repeater noise maker and if so where did you get it & how did you fit it?
Posts: 3,383 Likes: 12
Posts: 3,383 Likes: 12 |
It’s an often fitted accessory on motorbikes so maybe a search through a bike accessory website might give some leads?
BR Colin
Have a look at EBay item 392259024220 is that any good? (Might need a foam pocket to quieten it down a little?)
BR Colin
Posts: 5,046 Likes: 313
Posts: 5,046 Likes: 313 |
I think it was TBM on another thread who talked about one he'd fitted that only chirped up after ten seconds to be less annoying but remind the forgetful.
K Do you think I could fit one to her indoors....... ;-) BR Colin
Thanks Colin. What I am not so sure about is how to wire it in given PCBs etc. I don't want to blow up the electrics and he modern wiring diagrams are rubbish.
Posts: 7,895 Likes: 241
Posts: 7,895 Likes: 241 |
I have the same problem with mine, previously fitted an Audicator to the old S1 and it was very worthwhile, programmable delay & even dab the brakes to stop the beep.
But on the complex BCU used on the 3.7 I'm nervous of something going pop from potential backfeed
Hmmm needs checking out for sure, I have no idea. Too expensive to just guess, logic tells me no coils involved (as in a relay) so shouldn’t be a back EMF but I am a nuts and bolts mechanic not an electronics one so best get some expert advice. Sorry can’t help.
BR Colin
I think Richard Wood is our man to look at this
Agreed on Richard. I also thought that if I got two of those cheap bike repeaters I could wire one to each rear indicator & bring them back into the car via the board by the battery. But the indicators are canbus so I have no idea if that would tolerate that.
