1 members (moggin),
219
65
Topics49,861
Posts837,542
Posts: 3 |
I am about to take possession of a new PlusFour but although it will have a spare tyre there is no jack. Any advice please n what I should buy as would wish to use the jack to remove wire wheels for cleaning, many thanks
Posts: 37,419 Likes: 978
Posts: 37,419 Likes: 978 |
I'd be inclined to get your dealer to supply you with one as if god forbid there are any problems arising about lifting the vehicle your warranty should remain intact, or at least the dealer is responsible.
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
A trolley jack and some quality axle stands will serve you much better. The original jack is only intended for emergency tyre change use in my opinion. Presumably you'll be cleaning wheels on the comfort of your own drive, not the roadside; my supplied scissor jack is the hardest to use I've ever come across 😤💪🤺🤺
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 329 |
You should listen to +8Rich....the ONLY problem he has....relative to cleaning his magnificent car(s)... does Mrs.+8Rich have the butler immersed in other chores. If so, then he will have to wait.
2019 Morgan +4 2006 Mercedes Benz SL 600 2018 GMC SUV
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
My preference would be a bottle jack of the correct size they are small and compact...
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 5,587 Likes: 603
Posts: 5,587 Likes: 603 |
I use a trolley jack and axle stands at home ..... I intend to replace the scissor jack with a bottle jack ..... only downside of the bottle jack as a 'roadside' jack is that they are a bit heavier than the scissor jack ...... trolley jacks are available (at a price) in alloy for motorsport use but I have yet to find an alloy bodied bottle jack. I seem to remember reading (possibly on here) that Porshe cars have a nice quality alloy scissor jack .... these can be found on ebay not too expensive ... perhaps a forum member who has one could comment on the weight and ease of use.
Strange to supply a car with a spare wheel but no jack to fit it (can understand no jack if the car has no spare, just a repair/inflate aerosol) .... I know the AA/RAC will fit your spare at the roadside, but with the wait you have for them anywhere vaguely remote I don't fancy that as an option
Posts: 5,442 Likes: 468
Posts: 5,442 Likes: 468 |
Perhaps overkill for you dependent upon your all round requirements, I currently use this jack. https://www.machinemart.co.uk/p/clarke-ctj1500qulp-ultra-low-profile-1-5t-quic/important for me is the ability to get under a low slung chassis and one with a flat tyre.... As is I can run the jack under the bumpers to the front or rear crossmember, long enough to reach under the axle if that is a desire. I carry a scissor jack in it`s Morgan liveried pouch in the car. With no spare wheel, seems a gold card may be your best friend..! Good luck in your choices.
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
My preference would be a bottle jack of the correct size they are small and compact... Are there 10cm bottle jacks on the market?
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
As far as I remember this has been discussed before, and the advice that has been given is to get a used Porsche (944 or the like) scissor jack. No personal experience, but they are said to be very light, reliable and easy to use - as opposed to the quite bad OEM jack. Plenty on e-bay. This is for roadside use of course, in the garage is another matter.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
Have you looked in the tool tray? Lift the carpet on the parcel shelf & then the plywood cover.
