6 members (MATTMOG, MartinB60, PaulyG, Atlantic, Joske Vermeule, IcePack), 245 guests, and 80 robots.
+8Rich 76
Topics49,860
Posts837,520
Jonny72
Originally Posted by Robbie Mathisen
As far as I remember this has been discussed before, and the advice that has been given is to get a used Porsche (944 or the like) scissor jack. No personal experience, but they are said to be very light, reliable and easy to use - as opposed to the quite bad OEM jack. Plenty on e-bay. This is for roadside use of course, in the garage is another matter.
I use an aluminium (lightweight) trolley jack and axle stands when working at home.
Based on recommendations onTM, I did purchase one of the Porsche jacks to carry in the car.It is superbly made and quite light weight compared to the MMC original (on the Aero8).
Even though it was 'pre-loved' (from eBay) ,mine also came with the expanded foam holder which, sadly, I couldn't get to fit - but you may be able to on a trad.?
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
Image #664105 25/09/20 08:12 AM
Originally Posted by Image
I use a trolley jack and axle stands at home ..... I intend to replace the scissor jack with a bottle jack ..... only downside of the bottle jack as a 'roadside' jack is that they are a bit heavier than the scissor jack ...... trolley jacks are available (at a price) in alloy for motorsport use but I have yet to find an alloy bodied bottle jack. I seem to remember reading (possibly on here) that Porshe cars have a nice quality alloy scissor jack .... these can be found on ebay not too expensive ... perhaps a forum member who has one could comment on the weight and ease of use.
Strange to supply a car with a spare wheel but no jack to fit it (can understand no jack if the car has no spare, just a repair/inflate aerosol) .... I know the AA/RAC will fit your spare at the roadside, but with the wait you have for them anywhere vaguely remote I don't fancy that as an option
Bought one a few years ago, not yet used in anger but it has been tested in the garage under load & was ok, much lighter and more compact than the OE steel one, I also carry a small plywood pad just in case of soft ground
Pollok one nil #664119 25/09/20 09:24 AM
Hi chaps, I have looked at these porsche jacks before but with that raised oval how do you jack up the front cross member safely. Cheers paul.
Pmh44 #664126 25/09/20 10:29 AM
I built mine up to level using some hard rubber sheet (thanks to Stewart S for the tip thumbs ).
Cut the oval shape from the centre of 1 (or possibly 2) sheets of hard rubber sheet and glue securely to the top of the base.
This is very secure and has the added advantage of a built in pad to protect the crossmember.....
James
Monkey Z125
Pollok one nil #664128 25/09/20 10:53 AM
I made a lifting blocks which work really well with the Halfords trolley jack. It makes lifting the car much easier and safer.
Craig Jezz
Pollok one nil #664132 25/09/20 11:41 AM
Posting Desperado
Posting Desperado
Gone through a good few axle stands in the years TRY AND GET SOME RUBBER CAPS FOR THE TOPS OR USE A GOOD DUSTER FOR THE AXLE TO REST IN
using a WEBER A/STAND at the moment BUT STILL PUT JACKS UNDER AXLE ETC YOU CAN NEVER HAVE ENOUGH SAFETY
THE WEBER IS A 01376-- 323501 ESSEX 20045 2000KG GET SOME RUBBER CAPS FOR THE JACK HEADS IF YOU CAN OR AGAIN USE GOOD DUSTERS
TAKE CARE AS THE GARAGE HAS BEEN RAIDED TWICE THEY TOOK ALL MY TOOLS ETC AND MY LATE FATHERS SHAME THE RIDGE BACK ( DOG ) WAS NOT IN AT THE TIME HE IS NOT A LOVER OF PEOPLE HE DOES NOT KNOW.
Pollok one nil #664142 25/09/20 12:29 PM
I think the OP is asking about a jack for the new generation PlusFour (not the steel chassis +4).
Pollok one nil #664147 25/09/20 01:17 PM
Yes Graham, that's why I suggested he sought advice from his dealer these aluminium tubs are a whole new ball game and will need more care in jacking points is how I view it.
I refrained from advising the OP.
Pollok one nil #664156 25/09/20 02:05 PM
OK understood now Graham. They don't have tool trays or anywhere to put anything. Now I understand.
+8Rich #664529 27/09/20 04:50 PM
Yup, I agree with asking a dealer.
