2 members (Rovert, Bitsobrits), 334 guests, and 44 robots.
John V6 70
DaveW 66
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,996
RedThree
Page 2 of 4 1 2 3 4
We could practice our hand signals again, John!
S3 Roadster Brooklands LE 3/50.
Any after market indicator warning buzzer with high impedance trigger, which I assume most are, should be fine with the BCU. Only issue would be need for diodes in left and right feeds to keep indicators electrically independent.
FWIW have the same issue but have disciplined myself to cancel them - usually blush. Noting the neutral angle of the indicator stalk helps.
Richard, IIRC the Audicator had separate L/R connections to indicators & live trigger from brake switch and neg earth, I'll try and find my old wiring diagram
TBM Offline
Indicator Buzzer
Got one of these,
Wire to each indicator bulb, +ve and -ve, and then one that connects to the brake light circuit.
Adjustable delay to the buzzer, and using the brake silences it.
It sounds like the device you describe would be fine with a 3.7 Roadster Jon. The diode isolation I mentioned appears built-in given the individual trigger connections for left and right. If these and the brake light kill trigger are taken directly from the lamp feeds they would be after the BCU. This and the braking kill function suggest a logic driven device so no extra loading on the lamp circuits either.
Sounds awfully complex now with these ECU cars, but by chance I went for a good long test in a Mulsanne Speed 6.75 this week out to a vineyard and back , it had the most agreeable indicator noise that I have ever heard -reminiscent of a grandfather clock - not suitable for an open Mog though and you would expect special for almost the price of two McLarens out here!
99 plus 8 indigo
sid Offline
Hi John,
I've fitted the Audicator to my 3.7 Roadster with no problems at all - and it works a treat.
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue
Ex Indigo Blue '99 +4
Ex MogMMX Innovations winner
Black Rat
Black Rat
Originally Posted by John V6
Thanks Colin. What I am not so sure about is how to wire it in given PCBs etc. I don't want to blow up the electrics and he modern wiring diagrams are rubbish.
I bought a cheap motorcycle buzzer and fitted it into the rear indicator light circuit, works a treat I can hear up to about 60 mph.
Keith
2013 narrow bodied + 4 Ruby.
John V6 Offline OP
Keith,
I would be interested in a 3.7l owner who did that. The electrics I believe in terms of BCU etc are different.
How did you fit the buzzer to both sides? Was it via a common earth off the indicators?
2025 MG ZS EV aka Trigger
Originally Posted by sid
Hi John,
Very interesting & thanks Sid
Did you have to trace the connections all the way to the lights & use the original bullet points. or find something closer in the fuse box ??
Page 2 of 4 1 2 3 4
