Topics49,881
Posts837,805
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
No chance of getting an indicator feed from the fuse box as the common fused power feed is before the BCU, which then outputs feeds to each set of indicators directly, green/red n/s, green/white o/s. There are junctions where the feeds split to accommodate the side repeaters, so likely hookup points. For the brake light hookup you could use the brake switch connection, green/purple wire.
Posts: 155 |
Hi John,
I've fitted the Audicator to my 3.7 Roadster with no problems at all - and it works a treat.
Very interesting & thanks Sid Did you have to trace the connections all the way to the lights & use the original bullet points. or find something closer in the fuse box ?? I used the side repeater connectors under the wings, and a feed from one of the brake lights. I've used one of the front wing to inner wing screws as the earth, and made it so it's easy enough to access the permanently live feed on the starter motor for when programming the unit. I seem to recall the hardest part of it all was soldering the very fine wires supplied with the unit into bullet connectors, otherwise it was pretty straightforward - and certainly worthwhile.
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue Ex Indigo Blue '99 +4 Ex MogMMX Innovations winner
Posts: 8,690 Likes: 497
Posts: 8,690 Likes: 497 |
Hi John,
Very interesting & thanks Sid Did you have to trace the connections all the way to the lights & use the original bullet points. or find something closer in the fuse box ?? I used the side repeater connectors under the wings, and a feed from one of the brake lights. I've used one of the front wing to inner wing screws as the earth, and made it so it's easy enough to access the permanently live feed on the starter motor for when programming the unit. I seem to recall the hardest part of it all was soldering the very fine wires supplied with the unit into bullet connectors, otherwise it was pretty straightforward - and certainly worthwhile. Thanks Sid, that sounds like how I did it on the old S1 Roadster, but without all the elasictrickery bits to worry about
Posts: 6,672 Likes: 439
Posts: 6,672 Likes: 439 |
The one I bought has decent size wires so easy to fit crimp connectors to. I used a piggy back spade for the brake switch connection, and then bullets for the indicators.
No chance of getting an indicator feed from the fuse box as the common fused power feed is before the BCU, which then outputs feeds to each set of indicators directly, green/red n/s, green/white o/s. There are junctions where the feeds split to accommodate the side repeaters, so likely hookup points. For the brake light hookup you could use the brake switch connection, green/purple wire. Thanks Richard, very straightforward connections it's just a PiA to make a really neat job of hiding the additional wires which I dislike in the engine bay ![[Linked Image]](https://www.tm-img.com/images/2020/09/25/Audicator.jpg)
Posts: 84 |
The one I bought has decent size wires so easy to fit crimp connectors to. I used a piggy back spade for the brake switch connection, and then bullets for the indicators. I was trained to fix radar and telecommunications equipment right down to electronic component level, a system would have tens of thousands of components, and yet I look at this diagram and think...not for me! Boy have I become a luddite.
The one I bought has decent size wires so easy to fit crimp connectors to. I used a piggy back spade for the brake switch connection, and then bullets for the indicators. I was trained to fix radar and telecommunications equipment right down to electronic component level, a system would have tens of thousands of components, and yet I look at this diagram and think...not for me! Boy have I become a luddite. In fairness, that diagram looks far more complicated than the one I got with mine
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Keith, I would be interested in a 3.7l owner who did that. The electrics I believe in terms of BCU etc are different. How did you fit the buzzer to both sides? Was it via a common earth off the indicators? John John as I remember it was just a case of connecting a wire to the feed of each rear indicator and another to earth. The buzzer I fitted in the spare wheel compartment. When you activate the indicators power goes to the buzzer.
Posts: 188 |
I have fitted an audicator to my 3.o litre Roadster S1. The indicators don't self cancel when used on roundabout exits for instance. I just ran some wires down to the front indicators and the brake light feed. the small box of tricks/bleeper unit is screwed to the underside of the dashboard works a treat. even the hazard lights beep for fifty times and are then silent. i found that out this week when i ran out of petrol on the M6 because of the USELESS FUEL GAUGE. Fortunately the AA came to my rescue within 20 minutes.
2004 Silver Roadster S1
Posts: 318 Likes: 5
Posts: 318 Likes: 5 |
The one I bought has decent size wires so easy to fit crimp connectors to. I used a piggy back spade for the brake switch connection, and then bullets for the indicators. I was trained to fix radar and telecommunications equipment right down to electronic component level, a system would have tens of thousands of components, and yet I look at this diagram and think...not for me! Boy have I become a luddite. It's easy to understand your confusion. The diagram omits to show the convention of putting a dot where intersecting wires are connected. No dot where the wires just cross diagramatically. I have put a sounder onto the indicator relay of my '74 4/4. It makes such a racket that pedestrians in the street wonder what the noise is. It's a mechanical device (think relay that cycles it's own power) and sounds aweful. I must change it for something subtler. As a point of interest does the Audicator work with hazard flashers? Or should I say is inactive when hazards are on? Ooops just noticed Paul's post above!
