7 members (Morganmike, Ubiquitous, Jens, High Hamster, Moggo, RibbleAdventures, John V6),
269
New
Topics48,365
Posts813,360
Members9,215
Posts: 63 |
We could practice our hand signals again, John!
S3 Roadster Brooklands LE 3/50.
Posts: 7,943 Likes: 218
Posts: 7,943 Likes: 218 |
Any after market indicator warning buzzer with high impedance trigger, which I assume most are, should be fine with the BCU. Only issue would be need for diodes in left and right feeds to keep indicators electrically independent. FWIW have the same issue but have disciplined myself to cancel them - usually  . Noting the neutral angle of the indicator stalk helps.
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Richard, IIRC the Audicator had separate L/R connections to indicators & live trigger from brake switch and neg earth, I'll try and find my old wiring diagram
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
Indicator BuzzerGot one of these, Wire to each indicator bulb, +ve and -ve, and then one that connects to the brake light circuit. Adjustable delay to the buzzer, and using the brake silences it.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Richard, IIRC the Audicator had separate L/R connections to indicators & live trigger from brake switch and neg earth, I'll try and find my old wiring diagram It sounds like the device you describe would be fine with a 3.7 Roadster Jon. The diode isolation I mentioned appears built-in given the individual trigger connections for left and right. If these and the brake light kill trigger are taken directly from the lamp feeds they would be after the BCU. This and the braking kill function suggest a logic driven device so no extra loading on the lamp circuits either.
Posts: 1,530 Likes: 37
Posts: 1,530 Likes: 37 |
Sounds awfully complex now with these ECU cars, but by chance I went for a good long test in a Mulsanne Speed 6.75 this week out to a vineyard and back , it had the most agreeable indicator noise that I have ever heard -reminiscent of a grandfather clock - not suitable for an open Mog though and you would expect special for almost the price of two McLarens out here!
99 plus 8 indigo
Posts: 155 |
Hi John,
I've fitted the Audicator to my 3.7 Roadster with no problems at all - and it works a treat.
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue Ex Indigo Blue '99 +4 Ex MogMMX Innovations winner
Posts: 5,110 Likes: 56
Black Rat Charter Member
Posts: 5,110 Likes: 56 |
Thanks Colin. What I am not so sure about is how to wire it in given PCBs etc. I don't want to blow up the electrics and he modern wiring diagrams are rubbish. I bought a cheap motorcycle buzzer and fitted it into the rear indicator light circuit, works a treat I can hear up to about 60 mph.
Posts: 26,761 Likes: 425
Posts: 26,761 Likes: 425 |
Keith, I would be interested in a 3.7l owner who did that. The electrics I believe in terms of BCU etc are different. How did you fit the buzzer to both sides? Was it via a common earth off the indicators? John
Hi John,
Very interesting & thanks Sid Did you have to trace the connections all the way to the lights & use the original bullet points. or find something closer in the fuse box ??
