4 members (uvk33n, Ian B, Scrambledsignals, TBM), 409 guests, and 37 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,209
Georgetoad, woolfie
osten Offline OP
Hey guys,
3800ish km and the timing belt is about the give in. Thanks to you guys and other owners I did my homework and pre-emptively ordered a timing belt so that should go nicely. Aside from that its been running smoothly. (remember there's no dealer here)
Is there any other part I should get ? Because the book mentions a repair kit (tensioner belt, pulley rear idler, oil seal pinion, oil seal cam cover, repair kit, cam belt, pulley front idler, screw crome front cover). This all sounds overkill and I didn't read anything about that in previous posts.
On the community front i've gathered around 10 owners and we should be having our first meet in mid-October (there's no winter here).
I'm considering getting a cover for the air filter and paint it like a french aircraft roundel from ww2. What do you think?
Best,
E.
Piloting Saint Ex the Morgan
Instructions on what you require and how to replace the cam belt are freely available on the MTWC website: https://www.mtwc.co.uk/wp-content/uploads/2018/09/M3W-Cam-Belt-Change-modified.pdf. There does seem to be a bad batch of cam belts about that have surface cracking. Is there any other part you should get? The fuel pump should be replaced with a Walbro item : https://www.mtwc.co.uk/wp-content/u...-pump-replacement-April-2020-update.pdf. You don't want to break down in the middle of the desert!
My cambelt was replaced at 5K miles with lots of deterioation despite the spacer kit. I wonder if more active cooling is required? Especially in the desert! Mine had only done <2K in high temperature climate...
I am guessing this will be one of those "I will look at it this winter" items
Rodger
2004 Plus 8 (wife's)
