Topics49,870
Posts837,669
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
As has been discussed on these pages before, it would make life easier in the event that one has a seized/bound rear brake drum if there was a manual adjuster. I currently have the rear end stripped out for tyre & bearing change, and with plenty of time on my hands I reckoned now would be as good a time as any to investigate further. The drum components are mainly Lockheed so it didn't take long to find something on eBay that looked about right. ![[Linked Image]](https://www.tm-img.com/images/2021/02/26/Lockheed-adjuster.jpg) Here it is compared to the standard fixed item. ![[Linked Image]](https://www.tm-img.com/images/2021/02/26/Brake-Stuff_3-portrait.jpg) As you can see it slips right in. ![[Linked Image]](https://www.tm-img.com/images/2021/02/26/Brake-Stuff_5.jpg) ...and all looks very 'stock'. ![[Linked Image]](https://www.tm-img.com/images/2021/02/26/Brake-Stuff_4.jpg) I set up the adjuster so that the brake shoes are held the same distance apart as the standard fixed item. Just to be clear, I don't intend to use this as a regular adjuster because the standard automatic ratchet device works well most of the time. However, If my pads bind on the drum for some reason then it will now be a doddle to back off the adjuster to allow easy disassembly. Another 'Lockdown Project' complete!
Andy
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
What a very good find - might go looking for one of those myself!
Posts: 1,562 |
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
I think you must have found the last one
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Need to be creative with the search! Just found another one. He claims that he has five of them too, although they are a little more expensive than the one I bought. ![[Linked Image]](https://www.tm-img.com/images/2021/02/26/Screenshot-2021-02-26-at-13.38.33.png)
Andy
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
A very thoughtful modification!
Steve Late 2012 M3W
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
Found a cheaper one if anyone's interested. eBay item No. 124589834979 ![[Linked Image]](https://www.tm-img.com/images/2021/02/27/Screenshot-2021-02-27-at-10.14.39.png)
Andy
Posts: 70 |
Surely brake fade would not cause the pedal to go to the floor? This is exactly what brake fade does! Ask anyone that’s tracked cars hard. Fluid gets hot and things get spongy in a hurry. I would suspect that the bad adjustment overheated the drum, which then weakens the entire braking system. Have an unassisted like in the morgan and you’re close to the floor under normal conditions, the threshold to hitting the floor can be minimal.
Surely brake fade would not cause the pedal to go to the floor? This is exactly what brake fade does! Ask anyone that’s tracked cars hard. Fluid gets hot and things get spongy in a hurry. I would suspect that the bad adjustment overheated the drum, which then weakens the entire braking system. Have an unassisted like in the morgan and you’re close to the floor under normal conditions, the threshold to hitting the floor can be minimal. If brake fade is so bad that the pedal hits the floor, then the primary cause will be VERY old fluid that has absorbed moisture and reduced its boiling point dramatically. This moisure when hot forms bubbles in the fluid, which of course being compressible then proceed to do just that, losing all your braking ability. Anyone experiencing a really, really long pedal after a hard ession on track should look to change the fluid before the next session. A condition like this on the road should never really occur however, but if it does, then something is significantly wrong with the braking system and wants addressed ASAP.....!
