4 members (SailingTom2, MartinB60, Morganmike, TeddyAds), 163 guests, and 37 robots.
+8Rich 96
John V6 52
Topics49,898
Posts838,019
Page 4 of 4 1 2 3 4
Originally Posted by Lowflyer
I've used Comma G30 in my 2011 Plus 4 with super sport engine (Mazda MZR which is essentially a Duratec, an MX5 engine) for over 5 years since fitting my Mulfab ali rad. It is recommended to use an OAT antifreeze, i did change it in 2019 during routine maintenance using a 50/50 G30 and distilled water, no problems over this period.
I also use it in in my K series engined Elise which has something of a reputation for cooling issues, been using it for over 8 years 73k on the clock and no HGF issues or overheating. It is worth noting of the 2 companies Lotus and Rover one recommends OAT and the other recommends non OAT.
Unfortunately, OAT coolant shouldn't be used in Ford Crossflow engine due to its propensity to damage the older types of gaskets and seals.
Arwyn
TBM Offline
Arwyn
Agreed. I found this out shortly after flushing and adding OAT smile Thankfully only for a weekend and drained and put the proper stuff in.
I recently gave my system a good flush out with Thermocure. I'd given the block a good flushing in both directions before hand, so clean water was coming through, but the Thermocure managed to loosen and remove a whole ton of crap.
I don't have a manual fan, but all through the summer (I was doing some big miles - went to Cornwall and back twice which was usually fast dual carriageway, interspersed with stationary queues) the electric fan only came on a couple of times. The temp sender is pretty accurate as I changed to a solid state voltage stabiliser.
Re-routed the heater hoses, so that the bleed screw is now much higher and getting some good temps through the heater matrix at last.
AND fitted a new water pump/gasket and am no longer losing water (was losing about 1/4 litre every 200 miles).
Page 4 of 4 1 2 3 4
