12 members (cerealsurfer, Burgundymog, Slimbloke, TBM, Paul F, Happy super 3, +8Rich, Barkbark, chanteclair, bmgermany, Redfate, KennethM), 150 guests, and 91 robots.
+8Rich 66
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,881
Posts837,801
Page 3 of 4 1 2 3 4
No chance of getting an indicator feed from the fuse box as the common fused power feed is before the BCU, which then outputs feeds to each set of indicators directly, green/red n/s, green/white o/s. There are junctions where the feeds split to accommodate the side repeaters, so likely hookup points. For the brake light hookup you could use the brake switch connection, green/purple wire.
sid Offline
Originally Posted by sid
Hi John,
I've fitted the Audicator to my 3.7 Roadster with no problems at all - and it works a treat.
Very interesting & thanks Sid
Did you have to trace the connections all the way to the lights & use the original bullet points. or find something closer in the fuse box ??
I used the side repeater connectors under the wings, and a feed from one of the brake lights. I've used one of the front wing to inner wing screws as the earth, and made it so it's easy enough to access the permanently live feed on the starter motor for when programming the unit.
I seem to recall the hardest part of it all was soldering the very fine wires supplied with the unit into bullet connectors, otherwise it was pretty straightforward - and certainly worthwhile.
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue
Ex Indigo Blue '99 +4
Ex MogMMX Innovations winner
Hi John,
Thanks Sid, that sounds like how I did it on the old S1 Roadster, but without all the elasictrickery bits to worry about
TBM Online Content
The one I bought has decent size wires so easy to fit crimp connectors to. I used a piggy back spade for the brake switch connection, and then bullets for the indicators.
Thanks Richard, very straightforward connections it's just a PiA to make a really neat job of hiding the additional wires which I dislike in the engine bay
I was trained to fix radar and telecommunications equipment right down to electronic component level, a system would have tens of thousands of components, and yet I look at this diagram and think...not for me!
Boy have I become a luddite.
TBM Online Content
In fairness, that diagram looks far more complicated than the one I got with mine smile
Black Rat
Online Sad
Black Rat
Originally Posted by John V6
Keith,
I would be interested in a 3.7l owner who did that. The electrics I believe in terms of BCU etc are different.
How did you fit the buzzer to both sides? Was it via a common earth off the indicators?
John as I remember it was just a case of connecting a wire to the feed of each rear indicator and another to earth. The buzzer I fitted in the spare wheel compartment. When you activate the indicators power goes to the buzzer.
Keith
2013 narrow bodied + 4 Ruby.
I have fitted an audicator to my 3.o litre Roadster S1.
The indicators don't self cancel when used on roundabout exits for instance.
I just ran some wires down to the front indicators and the brake light feed.
the small box of tricks/bleeper unit is screwed to the underside of the dashboard
works a treat. even the hazard lights beep for fifty times and are then silent.
i found that out this week when i ran out of petrol on the M6 because of the USELESS FUEL GAUGE.
Fortunately the AA came to my rescue within 20 minutes.
2004 Silver Roadster S1
It's easy to understand your confusion. The diagram omits to show the convention of putting a dot where intersecting wires are connected. No dot where the wires just cross diagramatically.
I have put a sounder onto the indicator relay of my '74 4/4. It makes such a racket that pedestrians in the street wonder what the noise is. It's a mechanical device (think relay that cycles it's own power) and sounds aweful. I must change it for something subtler.
As a point of interest does the Audicator work with hazard flashers? Or should I say is inactive when hazards are on? Ooops just noticed Paul's post above!
Page 3 of 4 1 2 3 4
