0 members (),
315
43
Topics49,897
Posts838,017
Posts: 37 |
I am in the process of re fitting the radiator on my 1969 4/4 Ford Crossflow. The lower standard mounting brackets on the chassis are in such a position that the cotton reel rubbers sit below the brackets so that the radiator hangs on the cotton real. This to me seems wrong the radiator should sit on the cotton reel. The only solution as I see it is to move the standard chassis bracket down or modify the bracket on the radiator. Any comments pleas.
Martin R
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I have changed or repaired three if. My memory is OK and they have all been on top of t he mounting brackets.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Agreed, on top of the mounting brackets.
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
If we get some dry weather at the weekend, I'll get some photos/measurements of mine as a guide.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
The radiator's out of mine at the moment. I can take a photo later.
1972 4/4 2 Seater
Posts: 37 |
Thanks that would be great the bracket on the radiator are right at the bottom of the rad this might not be correct the position of the chassis brackets are I Think are in the original position
Martin R
Posts: 37 |
Martin R
![[Linked Image]](https://i.imgur.com/9nREraD.jpg) ![[Linked Image]](https://i.imgur.com/5sABWPO.jpg) There you go, hope that helps.
1972 4/4 2 Seater
Yep, same set up as mine.
Posts: 5,597 Likes: 617
Posts: 5,597 Likes: 617 |
Here's mine ![[Linked Image]](https://www.tm-img.com/images/2020/10/06/20201006_121619.jpg) K
