3 members (RedThree, Morganmike, SailingTom2), 232 guests, and 27 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
#665758 05/10/20 08:45 PM
I am in the process of re fitting the radiator on my 1969 4/4 Ford Crossflow. The lower standard mounting brackets on the chassis are in such a position that the cotton reel rubbers sit below the brackets so that the radiator hangs on the cotton real. This to me seems wrong the radiator should sit on the cotton reel. The only solution as I see it is to move the standard chassis bracket down or modify the bracket on the radiator. Any comments pleas.
Martin R
Ray Offline
I have changed or repaired three if. My memory is OK and they have all been on top of t he mounting brackets.
Agreed, on top of the mounting brackets.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
TBM Offline
If we get some dry weather at the weekend, I'll get some photos/measurements of mine as a guide.
TBM #665781 06/10/20 06:58 AM
The radiator's out of mine at the moment. I can take a photo later.
1972 4/4 2 Seater
Thanks that would be great the bracket on the radiator are right at the bottom of the rad this might not be correct the position of the chassis brackets are I Think are in the original position
Martin R
TBM #665793 06/10/20 09:12 AM
Martin R
There you go, hope that helps.
1972 4/4 2 Seater
TBM Offline
Yep, same set up as mine.
Here's mine
