10 members (Barkingdog, linklaw, jeremylparker, +8Rich, 3-Rad, Craig Jezz, MartO, Image, TalkMorgan, Mogdavid), 283 guests, and 48 robots.
Topics49,845
Posts837,373
#665826 06/10/20 02:28 PM
SAE Offline OP
Was wondering if anybody can give me some help on greasing the pedal bar on my 2000 plus 8.Everytime I hit clutch pedal it squeaks but clutch itself is fine.I looked at the bar and there are no grease nipples anywhere although on the left side there are 3 bolts holding down the aluminum block that holds the bar in and the other side only 2 so thought maybe the middle one comes out on the side with 3 and you can put a grease nipple in.Any help would be appreciated
2000 plus 8 Connaught green
1966 corvette
1928 Ford hot rod
2024 corvette
2009 porsche 911 4S
SAE #665842 06/10/20 04:27 PM
Squirty aerosol of grease works for me. This is diluted thin so it comes out the nozzle so gets everywhere before the dilutant evaporates off.
SAE Offline OP
Sprayed a lot still has the squeak wondering if piston rubber inside of clutch master cylinder could have hardened over time
1966 corvette
1928 Ford hot rod
2024 corvette
2009 porsche 911 4S
SAE #665869 06/10/20 07:43 PM
If you need to lubricate the cylinder do use silicone oil as normal oils will degrade the rubber seals!
Triumph Herald 1969 13/60
Morris 1970
