7 members (Rovert, Grumpy2, Montegue, DaveW, Burgundymog, Ritchie B, IcePack),
221
Topics49,846
Posts837,375
Posts: 29 |
Was wondering if anybody can give me some help on greasing the pedal bar on my 2000 plus 8.Everytime I hit clutch pedal it squeaks but clutch itself is fine.I looked at the bar and there are no grease nipples anywhere although on the left side there are 3 bolts holding down the aluminum block that holds the bar in and the other side only 2 so thought maybe the middle one comes out on the side with 3 and you can put a grease nipple in.Any help would be appreciated
2000 plus 8 Connaught green 1966 corvette 1928 Ford hot rod 2024 corvette 2009 porsche 911 4S
Posts: 8,665 Likes: 408
Posts: 8,665 Likes: 408 |
Squirty aerosol of grease works for me. This is diluted thin so it comes out the nozzle so gets everywhere before the dilutant evaporates off.
Posts: 29 |
Sprayed a lot still has the squeak wondering if piston rubber inside of clutch master cylinder could have hardened over time
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
If you need to lubricate the cylinder do use silicone oil as normal oils will degrade the rubber seals!
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
