Old Book
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
Topics49,937
Posts838,568
Posts: 6,696 Likes: 447
Posts: 6,696 Likes: 447 |
I've used Tolleys on my old Landrover. Only seemed to work on the very tiniest gaps. Didn't make a dent on the roof leaks.
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
I was brave today.
I threw a load of water in the heater box and zero ingress. Beaudy.
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 2,446 Likes: 78
Posts: 2,446 Likes: 78 |
Don't hold your breath I take it you were on stop at the time, good luck though. Em
“On stop” ?
Well I water tested before I sealed it up and it poured in so I reckon it’s a good start.
A very good start in fairness Lee
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
it's really good stuff - particularly for very fine cracks/leeks ; not sure if it will cure Kev's wet foot though....  James Hi James, thanks! That I have it now it in my amazon shopping basket. I was curious to understand more in detail what was meant with: "using on where the hinged bonnet attaches to the main structure"
Posts: 22,386 Likes: 359
Posts: 22,386 Likes: 359 |
it's really good stuff - particularly for very fine cracks/leeks ; not sure if it will cure Kev's wet foot though....  James Hi James, thanks! That I have it now it in my amazon shopping basket. I was curious to understand more in detail what was meant with: "using on where the hinged bonnet attaches to the main structure" The two screws which attach the rear bonnet hinge to the bulkhead are sometimes drilled right through, so water can get down the threads under the dash. Captain Tolleys will fix that.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
they were on my Roadster, I spent two weeks feeding the leak with CTCCC drops in the screw holes, allowed to run through and dry each time, the hole gets smaller and smaller as layers of CTCCC build up over each other, then it stopped.
If you get drips on the gearbox tunnel there is a good chance it's caused by that leak.
Yes I had water on my tunnel. It was the wiper spindles
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I've solved all my Morgan leaks,...I don't take it out in the rain.  .
