Morgan Aero 8
3 members (TBM, deano, Vansrv6), 175 guests, and 26 robots.
+8Rich 100
John V6 66
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,564
greenteagod
Page 4 of 5 1 2 3 4 5
TBM Online Content
I've used Tolleys on my old Landrover. Only seemed to work on the very tiniest gaps. Didn't make a dent on the roof leaks.
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
I was brave today.
I threw a load of water in the heater box and zero ingress. Beaudy.
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Don't hold your breath I take it you were on stop at the time, good luck though. Em
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
“On stop” ?
Well I water tested before I sealed it up and it poured in so I reckon it’s a good start.
2002 Aero 8 S1
A very good start in fairness Lee
Originally Posted by James B W
it's really good stuff - particularly for very fine cracks/leeks ; not sure if it will cure Kev's wet foot though.... innocent
James
Hi James, thanks! That I have it now it in my amazon shopping basket.
I was curious to understand more in detail what was meant with: "using on where the hinged bonnet attaches to the main structure"
James
The two screws which attach the rear bonnet hinge to the bulkhead are sometimes drilled right through, so water can get down the threads under the dash. Captain Tolleys will fix that.
they were on my Roadster, I spent two weeks feeding the leak with CTCCC drops in the screw holes, allowed to run through and dry each time, the hole gets smaller and smaller as layers of CTCCC build up over each other, then it stopped.
If you get drips on the gearbox tunnel there is a good chance it's caused by that leak.
Mark - No Longer driving
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Yes I had water on my tunnel. It was the wiper spindles
2002 Aero 8 S1
Ray Offline
I've solved all my Morgan leaks,...I don't take it out in the rain. stars.
