5 members (How, Image, JohnHarris, Wouter, scortroadster), 232 guests, and 34 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
Hi,
What Rover ECU is fitted as standard to this car? I have having trouble with a Emissions test; my CO2 reading is to high, one option could be a faulty ECU.
The one in the car is a replacement, the original went on the blip...
Its model number is MKC10115 YN. So Rover 820 2.0 16v 92-93 MEMS MP ECU
Is that what everyone else has?
Thanks
Will
Hi Will,
My 1993 Plus 4 T16 has MKC10034YN and is original as far as I know.
It starts well from cold, although is very inconsistent during the warm up cycle. Fine when hot.
The car has done 10000 miles
Regards
Simon
I have a 2000 car and a T16 rover engine, dont know the number on the ecu but I do have a spare and if you buy an obd cable you can use an app to fine tune the ecu...
Triumph Herald 1969 13/60
Morris 1970
here is the link to the reader you install on a phone and read /program
http://memsdiag.blogspot.com/2015/01/memsdiag-what-is-memsdiag-memsdiag-is.html
Morris 1970
It is a rover 820 unit. They fail regularly in my experience. Get one where the immobiliser is by passed also check the pipe from the manifold to the ECU for leaks.
They tend to fail due to getting too hot.
When mounting a small amount of heat compound should be used - but a very small amount. Too much and it will act like an insulator.
I had a 1997 +4 and the MEMS unit was MKC104081
At one time I had a fault that I was trying to trace and got another one off eBay with the same reference, had to get BHM to program it to recognise the immobliser. That didn't fix the issue but it meant I had a spare.
Tim
Plus 4 2018
