Posts837,275
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
I have failed miserably to stop my doors squeaking when the side screens are fitted. Can anybody recommend a fix? Thanks in advance.
Roger 2011 Plus 4
Posts: 192 Likes: 3
Posts: 192 Likes: 3 |
I wish I knew as well, have tried bending the rear stay as the screens were so tight against the body that they have printed the material in to the paintwork. This did help a bit with the squeaks but they are still there.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
Things I've done:
Neoprene tape on bottom edges of door tops (where they meet the door = seals gaps, makes a tight fit and invisible to see) Librands door top stay Extra silicon around edges of perspex Chunk of U channel rubber seal that fits on the edge of the windscreen frame (push fit on the draught excluders)
Posts: 2,583 |
I`ve put paint protection film about 1" wide along the tops of the doors - stops squeaking and rubbing of the paint if dust/grit gets in.
Posts: 829 Likes: 22
Posts: 829 Likes: 22 |
1980 +8 Blue And a few others ---------------- Stephen
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
I rub a tiny bit of clear tyre dressing into all the rubber seals where they contact any bodywork or the sidescreen alloy, works for me
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
The squeaks on my +4 get worse when I have cleaned and polished the car The handbook tells me at least every month to Check and lubricate door rubber weatherstrips. No clue as to what to use but been thinking of using silicon grease.
Tim Plus 4 2018
Posts: 1,242 Likes: 30
Posts: 1,242 Likes: 30 |
Many moons ago I had an S2000. To stop squeaks From the soft top they sold a Tube of silicone grease for the rubbers. Even had a part number.
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
Me too. I have one particularly annoying squeak that seems to move around behind my ear. No idea what it is.
Kevin
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Use tyre dressing or rubber shine. The squeaking is often where the sidescreen overlaps the B panel, and without paint protection film can eventually mark the paint.
