10 members (Barkingdog, linklaw, jeremylparker, +8Rich, 3-Rad, Craig Jezz, MartO, Image, TalkMorgan, Mogdavid),
283
48
Topics49,845
Posts837,373
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
There is also a plastic T piece on the hose from the expansion tank & to the heater. They get brittle so I replaced mine with an ali one from Simon of SiFab ![[Linked Image]](https://www.tm-img.com/images/2017/12/04/20171204_104333.jpg)
Posts: 502 |
Hi Dave W, I think that rules out a split hose, as the temp gauge went close to nearly the maximum. I've had a feel around as best I can and can't find a split. The thermostat housing has evidence of leakage. After filling it with water yesterday, it was running at a normal temperature, until going sky high again. Steam escaped first and second time, but when topping it up a second time water was dropping out quite quickly from somewhere. Gonna top up again for some clues.
2004 Series 1 Roadster
Posts: 502 |
Been digging around and found out I have a cracked thermostat housing. I think this may have been caused by the sudden on rush of cool water being put into the expansion tank, although it was left for a good 20mins. From evidence around the adjoining clips, it looks like there may have been a leak from here before, to I'm hoping that once I replace this, and remove excess oil that I topped up to sort out the oil pressure issue, then I'll be a happy bunny. Any advice in which housing I need to buy for 2004 roadster?
Posts: 1,415 |
Been digging around and found out I have a cracked thermostat housing. I think this may have been caused by the sudden on rush of cool water being put into the expansion tank, although it was left for a good 20mins. From evidence around the adjoining clips, it looks like there may have been a leak from here before, to I'm hoping that once I replace this, and remove excess oil that I topped up to sort out the oil pressure issue, then I'll be a happy bunny. Any advice in which housing I need to buy for 2004 roadster?  Mondeo ST220 I did reply to your post on Facebook....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 502 |
Yeah, thank you for all your advice. Any advice on fitting the damn thing when I get one. I have tried to remove some of the hoses but some have clips that you pinch, in a seemingly inaccessible location. If the clips where all facing towards me it would be a lot easier. There really isn't much room where it is fitted.
Posts: 1,415 |
Patience and having extra joints in your fingers.....
The clips are all fitted when the engine is dressed before it goes in the car
Simon @ Sifab.co.uk
Posts: 5,437 Likes: 467
Posts: 5,437 Likes: 467 |
Some hose pipe clips are tightened/loosened by slotted screws that may also have 8mm heads which allow use of a socket, spanner or bladed screwdriver, an 8mm spanner may be small enough to allow accces into tight places. There is also a possibility that a flexible socket drive might provide access similar to the one in the link..? Good luck. https://www.ebay.co.uk/i/2931426588...W7ZQPVDExWKlv1sERB3TT-EqvthoCZqEQAvD_BwE
Posts: 8,665 Likes: 408
Posts: 8,665 Likes: 408 |
I favour an 8mm (or 6mm for smaller hose clips) ring spanner, but be aware of the extra torque you can get on the clip drive. A ¼" square drive socket can work as well if there's clearance. A smear of grease on the clip drive helps as well and saves corrosion long term.
Posts: 502 |
A couple of the clips have screw heads but the awkwardly placed clips have the ones you need to squeeze with pliars. It's all frustrating 😤
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
A couple of the clips have screw heads but the awkwardly placed clips have the ones you need to squeeze with pliars. It's all frustrating 😤 Just snip or Dremel them off, then use new when you reassemble & you can position them to be accessible for re-tightening
