9 members (hillclimber, Soleng, Ubiquitous, Alistair, How, MogOnTheMove, jbk, RichardV6, DaveW), 291 guests, and 45 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts813,000
RedThree
#67051 22/08/11 10:47 PM
dale2 Offline OP
Can someone please tell me how to repair a leaking two outlet reservoir?? I cannot undo the outlet pipes to put in new seals or gaskets. All help would be appreciated. Dale frown sos
A little more info would be helpful.
'65 +4 four seater
Please post a photo if you can.
Brake master cylinder with dual circuits??
dale2 Offline OP
Sorry, I can't get a photo but the reservoir has the two lines out (at the base) and one line is leaking and it is loose with some sort of gasket as a seal. I cannot tighten or unscrew it to see what kind of seal is needed. The inside has a divider and it does not allow a socket to catch the interior nut. Hope this description helps and someone will have had this problem before and has figured it out. Dale
(a) What model is it?
(b) What year?
(c) Is this the brake master cylinder?
1972 4/4 2 Seater
dale2 Offline OP
This is not the master cyl, it is the reservoir that feeds both the brake and clutch cyls. It is a can with the two outlets on the base.
