2 members (DaveK, M3WMW),
239
35
Topics49,911
Posts838,148
Posts: 59 Likes: 1
Posts: 59 Likes: 1 |
Hi all , MoT coming up and windscreen washers don’t work so before I start stripping the car to bits can anybody shed some light on where the motor is or any other issues that may cause them not to work ? I’ve actually never used them
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
A common issue is the pipes either coming off from the jets or disintegrating behind the dashboard. Consequences can mean damage to electrical components, so don’t keep trying unless you are sure that’s not the problem.
Posts: 59 Likes: 1
I don’t think they working at all as I can’t here any noise when I try to use them
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
I don’t think they working at all as I can’t here any noise when I try to use them Fuse blown ?
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
You don’t say which Morgan you have, but on my 2014 car the washer pump is attached to the windscreen washer bottle on the near side. I’m with Jon - check the fuse first.
Posts: 37,486 Likes: 993
Posts: 37,486 Likes: 993 |
You don’t say which Morgan you have, but on my 2014 car the washer pump is attached to the windscreen washer bottle on the near side. I’m with Jon - check the fuse first. It's the header Paul
You don’t say which Morgan you have, but on my 2014 car the washer pump is attached to the windscreen washer bottle on the near side. I’m with Jon - check the fuse first. It's the header Paul  Doh!
Posts: 322 Likes: 3
Posts: 322 Likes: 3 |
The washer pump is at the base of the washer fluid bottle, if you cannot hear the pump running it could be an electrical fault, or the pump could be seized. I have found that if they are not used the washer fluid can develop a black sludge that jams the pump. Had to take the bottle off my Plus 8 and give it a thorough clean.
--------------------------- Mike Smith
2007 +4
I've done it a few times myself
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Or mould could have built up in the outlet pipe
