3 members (Morganmike, DJC, Rastus), 143 guests, and 32 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
#671460 07/11/20 04:40 PM
Fus969 Offline OP
Hi all , MoT coming up and windscreen washers don’t work so before I start stripping the car to bits can anybody shed some light on where the motor is or any other issues that may cause them not to work ? I’ve actually never used them
A common issue is the pipes either coming off from the jets or disintegrating behind the dashboard. Consequences can mean damage to electrical components, so don’t keep trying unless you are sure that’s not the problem.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Fus969 Offline OP
I don’t think they working at all as I can’t here any noise when I try to use them
Fuse blown ?
You don’t say which Morgan you have, but on my 2014 car the washer pump is attached to the windscreen washer bottle on the near side. I’m with Jon - check the fuse first.
Costock, UK
Disco 5
It's the header Paul thumbs
Doh!
Costock, UK
Disco 5
The washer pump is at the base of the washer fluid bottle, if you cannot hear the pump running it could be an electrical fault, or the pump could be seized. I have found that if they are not used the washer fluid can develop a black sludge that jams the pump. Had to take the bottle off my Plus 8 and give it a thorough clean.
Mike Smith
2007 +4
I've done it a few times myself grin2
Or mould could have built up in the outlet pipe
