2 members (+8Rich, DaveK), 324 guests, and 34 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,087
Felix42 #671891 09/11/20 07:44 PM
TBM Offline
Originally Posted by Felix42
This LED headlight bulb has no control box, albeit a little more expensive:
https://www.ledperf.co.uk/h4-bi-led-bulb-conversion-kit-p-25957.html
£30 cheaper at Classic Car LEDs H4 LED
Alexander #671925 10/11/20 08:21 AM
So how would these fit into a sealed unit? TBM , you have obviously done the conversion!
Alexander #671929 10/11/20 08:43 AM
I doubt a Mog is still using genuine sealed beams, they would be very old & the lifespan was not good
thelastgizmo #671930 10/11/20 08:45 AM
I have several of the newer non sealed beam headlight shells. Your are welcome to a pair if you can make it down to Felixstowe or we meet part way to wherever you are in Norfolk.
I have the Classic Car Lighting ones fitted.
thelastgizmo #671932 10/11/20 08:55 AM
TBM Offline
Hi - not done an LED conversion (although have used the company for rear and sidelights) but have converted to H4 front lights from sealed beam. Very easy swap over. I went for the Wipac Crystal 7" - I like the look of them, and used them on both my Land Rovers, so am happy with the light spread.
I also went for sidelights in the lens and spliced them into the wing mounted sidelights - bit of a belt and braces approach. Had to trim a 'U' shape out of the backing plate to fit the sidelight bulb holder. If you do the conversion, you will need to use relays for main/dip - I fried my dim/dip stalk switch with a week of upgrading!
Once you've done the conversion, it would be easy to upgrade to the LED's if required, especially the ones without the control box.
CooperMan #671933 10/11/20 08:58 AM
TBM Offline
Mine were still working fine after 47 years - only did the swap as I wanted the ease of a H4 bulb as they're available in most garages and I do a shed load of touring.
CooperMan #671936 10/11/20 09:12 AM
Replacing a sealed beam unit was the first job I did on my Morgan so that one is 13 years old. The other was on the car when I bought it - It may, for all I know, be the original. The sidelight bulbs, however, used to blow regularly until I replaced them both with LEDs.
2011 Morgan 4/4
1932 Austin 7 Chummy
TBM #671940 10/11/20 10:19 AM
You're right, I have a pair of genuine Lucas units dated 1967 that still work, saved for Mini concours comps, but the replacement stuff is a bit naff so for daily use I run with H4 conversions
TBM #671969 10/11/20 01:25 PM
Mine are still ok after 46 years also. Assuming they are the originals. When I removed them to check the voltage at the bulb I noticed they said Made in Canada (RHD) on the back.
I've just done a relay conversion for the main, dipped and spot lights. Certainly improves things.
John V6 #672071 11/11/20 11:17 AM
Hi John, thanks very much for the offer. When we are let out again I may take you up on that. I did the halogen upgrade to my MGB which was almost dangerous to drive at night! I'm finding my night vision is not what it was. One of the disadvantages of getting old! So the more light the better.
