7 members (Barkbark, Simon, Soleng, tommog, TBM, Morganmike, paulmog),
140
Goodwood
Topics49,929
Posts838,460
Posts: 2,122 Likes: 72
Posts: 2,122 Likes: 72 |
I haven't even thought about a bumpstop yet. The factory fitted two rubber blocks beneath the seat frame. I am just guessing that nobody really wants to experience what happens if the axle hits those hard  The ones you make look like a good solution to me. In order to get the right height of the bump stop brackets I would need to find the shock position when it is fully compressed and add the height of the rubber block when being compressed, right? BTW: Who is Rog ?  Have a look at this link! A fantastic improvement to many cars! Info about Rog´s bump stops
Posts: 6,690 Likes: 445
Posts: 6,690 Likes: 445 |
I haven't even thought about a bumpstop yet. The factory fitted two rubber blocks beneath the seat frame. I am just guessing that nobody really wants to experience what happens if the axle hits those hard  The ones you make look like a good solution to me. In order to get the right height of the bump stop brackets I would need to find the shock position when it is fully compressed and add the height of the rubber block when being compressed, right? BTW: Who is Rog ?  Have a look at this link! A fantastic improvement to many cars! Info about Rog´s bump stopsBut only possible if you have a rear hoop, and if you have shocks without buitl in bump stops. If you have Spax Shocks, they have built in bump stops, or you can put a bumpstop on the damper rod.
Posts: 8,713 Likes: 419
Posts: 8,713 Likes: 419 |
I made some bumpstop brackets for mine - i don;t think the AVO shocks have them built in (SSL recommend another type of shock which has a built in bumpstop, negating the need for additional stops, like I've made or the ones Rog sells)
PJB was under the impression AVO's didn't have compression bump stops but I found my (front) ones did albeit polyurethane. Nevertheless he persuaded me to use the Spax gas shocks they spec with their front RS kit. Assume rear AVO's do as well - easy enough to check - just pull back and release the soft plastic dust cover.
PJB was under the impression AVO's didn't have compression bump stops but I found my (front) ones did albeit polyurethane. Nevertheless he persuaded me to use the Spax gas shocks they spec with their front RS kit. Assume rear AVO's do as well - easy enough to check - just pull back and release the soft plastic dust cover. That's good to know - negates the need for the additional bump stops. Only have front shocks (AVO) on mine.
Posts: 153 Likes: 1
Posts: 153 Likes: 1 |
Whow - I had a look at Rog's bump stops and then found his planetary box here: Malvern Arms forumQuite a piece of work. But I also learned: on the four seater with the Rutherford side bracket those bump stops won't work. And I double checked on the AVO website. AVOUK - their shocks have a 1" bump stop built-in. Now off to the garage: I hope to have a rolling chassis by tonight
Now off to the garage: I hope to have a rolling chassis by tonight  Good luck! Hope it all goes well. Keep us posted. And good news about the bump stop in the AVO - means you won't need any additional support.
Posts: 153 Likes: 1
Still some work to do before it is a rolling chassis - but the rear suspension is in and hopefully finished. ![[Linked Image]](https://fixingc6622.files.wordpress.com/2020/11/rearsuspenionfinished.jpg) More can be found here: FixingC6622
Glad you managed to get it sorted. Looking very smart.
Have you thought about a bash plate for the tank, where the handbrake mount is? Opinion is divided, but I fitted one as it was easy, and there was no detrimental affect.
Like this; ![[Linked Image]](https://www.tm-img.com/images/2020/05/05/8uZ5En44kUpI1-oCxt2liCZX5MAtbnIzbbtNBMTkZiWxsCnphusyZMPwAPePGYlBf9DUEsdiOUCyAGN8RVgUfCHH26DHTu38QDHvFQVAH_aKXBdq5WdSdhReQBbMCY0oy4mVGKXUc_Rc0L3aKDXwB0zUkDfQjdtR5Ba922YyIP2qgcoIPi2ueTD37yw61jyRT4DzFMKO.jpg)
Posts: 27,859 Likes: 774
Posts: 27,859 Likes: 774 |
Well done. Good to see the progress
