6 members (Barkingdog, RichardV6, Simon, Image, Lord Sward, Tresco), 138 guests, and 23 robots.
+8Rich 103
John V6 67
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
International Morgan Day
by Deejay - 17/09/26 02:45 PM
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,929
Posts838,458
Fuel.inj
Page 3 of 4 1 2 3 4
Originally Posted by TimB
I haven't even thought about a bumpstop yet. The factory fitted two rubber blocks beneath the seat frame. I am just guessing that nobody really wants to experience what happens if the axle hits those hard wink
The ones you make look like a good solution to me. In order to get the right height of the bump stop brackets I would need to find the shock position when it is fully compressed and add the height of the rubber block when being compressed, right?
BTW: Who is Rog ? smile
Have a look at this link!
A fantastic improvement to many cars!
Info about Rog´s bump stops
TBM Offline
But only possible if you have a rear hoop, and if you have shocks without buitl in bump stops.
If you have Spax Shocks, they have built in bump stops, or you can put a bumpstop on the damper rod.
Online NoMood
Originally Posted by TBM
I made some bumpstop brackets for mine - i don;t think the AVO shocks have them built in (SSL recommend another type of shock which has a built in bumpstop, negating the need for additional stops, like I've made or the ones Rog sells)
PJB was under the impression AVO's didn't have compression bump stops but I found my (front) ones did albeit polyurethane. Nevertheless he persuaded me to use the Spax gas shocks they spec with their front RS kit. Assume rear AVO's do as well - easy enough to check - just pull back and release the soft plastic dust cover.
TBM Offline
That's good to know - negates the need for the additional bump stops. Only have front shocks (AVO) on mine.
TimB Offline OP
Whow - I had a look at Rog's bump stops and then found his planetary box here: Malvern Arms forum
Quite a piece of work. But I also learned: on the four seater with the Rutherford side bracket those bump stops won't work.
And I double checked on the AVO website. AVOUK - their shocks have a 1" bump stop built-in.
Now off to the garage: I hope to have a rolling chassis by tonight wink
TBM Offline
Good luck! Hope it all goes well. Keep us posted.
And good news about the bump stop in the AVO - means you won't need any additional support.
TimB Offline OP
Still some work to do before it is a rolling chassis - but the rear suspension is in and hopefully finished.
More can be found here: FixingC6622
TBM Offline
Glad you managed to get it sorted. Looking very smart.
Have you thought about a bash plate for the tank, where the handbrake mount is? Opinion is divided, but I fitted one as it was easy, and there was no detrimental affect.
TBM Offline
Like this;
Well done. Good to see the progress
Page 3 of 4 1 2 3 4
