5 members (Pittsartist, Burgundymog, Morganmike, Tony Quinn, RichardV6), 274 guests, and 49 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,331
Christoph
Page 5 of 6 1 2 3 4 5 6
Phil Bleazey #673869 20/11/20 09:24 PM
Cracked chassis with bolt in A frame
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
hugo #673894 21/11/20 07:01 AM
I
I
That’s horrible. I’m pretty sure that my car came out of the factory with the bolt in A frame fitted (and it does seem to be well fitted) and other typical fixes of the period. However the front wishbone mounts do not have fillets on the welds, so it’s a muddle and not easy to work out exactly where I sit in the overall chassis evolution given the 2015 registration. At this time after 2000 miles I don’t have any visible frame cracks and strangely my original Brooklands exhaust system is thus far crack free. Guess I’ll just have to keep checking and take the pain if it ever comes. Though I’m wondering if it ever develops cracks, what MMCs future stance would be on frame replacement?
M3W Brooklands (2015)
Moody 41 (2013)
Phil Bleazey #673915 21/11/20 09:15 AM
JMD Offline
My theory is that cracks initiated quite quickly in the original chassis (ie micro cracks that are not visible) - without the bolt in brace, they also propagated quite quickly and became visible (we shared this experience with many early owners and had a rebuild). The bolt-in brace has at least slowed propagation for those with the early chassis but with the number of cars with the brace now showing cracks, it looks like not being enough. The good news so far is that the replacement chassis with welded in brace (and other changes?) appears not to crack...
JMD #673932 21/11/20 10:14 AM
I
I
I agree JMD, a bolted in brace (from scratch) should be as good as a welded brace of similar geometry if fitted properly. As mine appears to be fitted in the factory before the vehicle was sold I’m reasonably hopeful that there were no cracks already present, my main area of concern is the lower wishbone brackets which don’t have the welded fillets so I’m going to ask MMC about that.
Moody 41 (2013)
Phil Bleazey #673934 21/11/20 10:24 AM
IMHO
One of my (late-2016) lower wishbone bracket bushes failed a couple of years ago, taking me into a tree! A couple of fabricators have suspected weakness in the HAZ, but I have not heard of other instances.
M3W55 #673968 21/11/20 12:21 PM
I
I
Originally Posted by M3W55
IMHO
Scary. I guess the one advantage of a timely bolt in frame is that there’s no HAZ.
Has anyone had an in situ frame modified by welding e.g wishbone brackets?
Moody 41 (2013)
planenut #674106 22/11/20 09:46 AM
Originally Posted by planenut
[quote=IMHO]
If you have a pre 2014 specification chassis car, I suggest you familiarise yourself with what and where to check on the chassis and check it periodically. A scheduled dealer service is no guarantee that the chassis will not be cracked. As mentioned, the information is freely available on the MTWC website.
This is getting more worrisome now MMC stopped the production !! What will happen when e.g. you own an older M3W and gets a cracked chassis in the upper part ? Most (perhaps all ?) previous cases did got a new chassis at MMC. But how will it look like in two or three years (or even more) when you get a cracked chassis ? Does MMC still have a chassis for you in stock ? Do they still change your chassis ? Will it be still guaranty ? This questions is hanging as a dark cloud above the heads of owners with a pre 2014 M3W.
www.m3w-jungfrau-treffen.com
IMHO #674126 22/11/20 11:16 AM
IMHO
My experience is that every chassis crack I have seen (I have only seen lower ones by the wishbone attachment) Starts in the heat affected zone (HAZ) and propagates round the tube from there. The stresses in this welded area are enormous.
Phil Bleazey #674128 22/11/20 11:33 AM
If you want to check the chassis for cracks then, as planenut says, familiarise yourself with where the cracks usually appear and do the following :-
1/. Wipe the area clean and spray the area with penetrating oil ( WD40 for example)
2/ Wait for 5 minutes and then wipe away all of the surface spray residue.
3/ take some powdered French chalk - the sort of thing you use on an inner tube before fitting a tyre or rub any piece of chalk on sandpaper to produce a powder - Blow the powder over the area where the cracks appear and if a crack its present t will magically develop as a stain in the chalk.
This is only a DIY version of professional crack detection but much better than the naked eye inspection and usually shows up cracks you otherwise won't see.
One of our problems is that, in the UK, repairs to motor chassis and body shells must be done by welding, if the vehicle is to pass an MOT test. A well designed brazed repair is much stronger and leaves no heat affected zone or localised stresses. A motor manufacturer obviously has to abide by the rules. I cheat!
Phil Bleazey #674129 22/11/20 11:44 AM
The picture of the crack/break that i have posted is just behind the rear upper wishbone mount, there was also a crack on the other side, one year previously i had the fillets fitted to the lower wishbone mounts.
