3 members (JohnHarris, TalkMorgan, Graham, G4FUJ), 331 guests, and 97 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
#673237 17/11/20 05:00 PM
NeilMB Offline OP
I am relatively new tot he forum in terms of posting threads, but I thought it would be a good moment to reflect on 18 months of living with my Plus 4 (2010 vintage). Very much a boyhood ambition to own a Morgan, and it makes me smile every time I drive it.
Living with it one understands the "Heath Robinson" nature of some of the design aspects but the nice thing is there are plenty of people here on the forum with useful advice.
Over the last year I have been working on some improvements, (when I say I, I really mean Cain at Wolf Performance).
Started with a panhard rod, which really made a difference, then a front suspension rework and adjustable dampers all round. A cumulative effect but has really made the car so much better on the road, planted rather than skipping around.
Today had the ECU remap , smoother power delivery and a little more torque which extends the gearing, plus a new set of nice aluminium pedals.
One of my very first posts was in relation to the fitted organ pedal which jammed wide open on two occasions (the roller was trapped in the rough casting when the pedal was floored), very scary at the time. Organ pedal removed the next day.
The new pedal plates work really well, adjustable left to right and up down. Much more comfortable and natural for my size 11's. There is also space to extend the left foot between the clutch and brake for longer spells.
I tried to attach a photo but the attachment manger was having none of it.
An interesting journey of improvements, trying to keep the old world charm and characteristics but making the car so much better at the same time.
just looking forward to a post covid situation when there are long journeys to be had.
Regards Neil
Neil,
i can post them if you want if you email me. Have pm sent with my address.
Cain & Michele are a great support to us & we are working in a better throttle pedal for my 3.7l Roadster so it doesn't sit lower than the brake.
NeilMB Offline OP
Cain altered the brake setting so now the new accelerator pedal and brake pedal are in the same plane,
Neil
And here is the pedal box photo for Neil
Rather like those.
Could do with similar (larger) for the 90, too!
With added note:
Originally Posted by demon-tweeks
Please note -
Pedal extensions are for off-road and show use only.
Trouble with them is they mount to the pedals, not a problem in the Morgan, but I don't want to reduce the leg room on the 90. I do sometimes wonder whether the pedals from an S11/S11a would fit... smile
But note, the spec states for off road and show use only, which suggests they are not road/MOT friendly.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Could be because they don't have rubbers, but you could use that stick on skateboard gripper (which is OE on later Roadsters)
I don't believe drilled pedals need rubbers. I suspect it is something to do with the fitting to OE pedals.
