Posts837,998
Posts: 552 |
Dave, did you keep with the sticky tape for your clock.
I have found that the tape I have, which has successfully held rubber trim etc, fails when the car gets hot , whilst parked. My carefully aligned (black faced, black surround) clock now sits 5 or 6 mm lower than its optimal spot having slipped on the tape.
Is there a secret? before I get the drill out
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
So far it's stayed put, but hasn't been in direct sun. The tape I used is from Halfords with a green backing. It's black tape, and wide, but quite thin. When I use it on the rally Plaque holder it lasts easily over two days and takes some shifting. I also use it behind my leather fripparies, and nothing has dropped off yet, so I'm optimistic.
Posts: 552 |
Cheers Dave, I'll check out halfords before I fire up the black and decker
Posts: 7,934 Likes: 133
Posts: 7,934 Likes: 133 |
Cheers Dave, I'll check out halfords before I fire up the black and decker If you really want it to stick, bathroom mirror tape will do the trick; however, be warned, once stuck down, it tends to stay in place. I use it for my registration plates and they have been known to crack before I can get them unstuck from the car. A small piece would do the trick but as I'd only use it as a last resort before the drill.
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
I use industrial strength Velcro. The. Lock has stayed put!!
Cheers!
That should have read " the clock" stays put!!!
Posts: 220 |
That last sentence makes a great quote.......
Posts: 295 Likes: 5
Posts: 295 Likes: 5 |
Chuffed to bits with my Chronos clock ... until it stopped working  . Bought some new batteries, fitted the replacement (fiddly - but easy) - same result. The seller couldn't have been more obliging - sent a replacement clock by return of post ... which has now also stopped  Has anyone else had this problem? I'm so glad I didn't drill the dash to fit the mount (or even worse - cut a hole!). At least if I can't get one that keeps working long term, I've not ruined the dash.
Nick Connaught Green Roadster S3 V6
Posts: 102 |
Chuffed to bits with my Chronos clock ... until it stopped working  . Bought some new batteries, fitted the replacement (fiddly - but easy) - same result. The seller couldn't have been more obliging - sent a replacement clock by return of post ... which has now also stopped  Has anyone else had this problem? I'm so glad I didn't drill the dash to fit the mount (or even worse - cut a hole!). At least if I can't get one that keeps working long term, I've not ruined the dash. Yup , the first one stopped after 3 days, the promised replacement arrived 10 days later after email and telephone reminders.
Kevin Black/tan 4/4 sport
Mine is still working and still mounted with Velcro!!
