5 members (Sir Percival, Soleng, Graham, G4FUJ, Hamwich, Ritchie B), 176 guests, and 43 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,340
Christoph
Page 4 of 6 1 2 3 4 5 6
Phil Bleazey #673017 16/11/20 01:54 PM
The Chassis brace was free of charge and all(?) owners at the time would have received a letter from MMC and/or their dealer.
Red Leader drive
Phil Bleazey #673129 16/11/20 08:56 PM
There is a guy selling his 2013 with “crankshaft damage” on Facebook?
kankeL #673382 18/11/20 01:15 PM
Thanks for the tip - no reply from him yet and I'm not sure how easily I could sell a left hander on.
Chris99 #673739 20/11/20 09:39 AM
Bolt in brace was free but did not work. Mine still cracked
TimG #673744 20/11/20 09:54 AM
I
I
Really? I’ve not picked up on this before, I have a bolt in brace despite being a 2015 registered vehicle and now I’m worried! scared
M3W Brooklands (2015)
Moody 41 (2013)
IMHO #673747 20/11/20 10:00 AM
I also had a bolt in brace,my chassis cracked and had to be replaced
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
IMHO #673756 20/11/20 10:34 AM
Although your car was registered in 2015 it was manufactured before then and has a pre-2014 specification chassis. With that in mind you should be aware of the crack issues for the upper rear wishbone tube and lower forward wishbone mount areas. There are articles about where and what to check on the MTWC website as well as in the buyers guide https://www.mtwc.co.uk/news-post/
Phil Bleazey #673781 20/11/20 01:56 PM
I
I
I have the bolt in “A” frame, I’d always associated continued cracking problems with the original simple bolt in cross piece not the “A” frame?
Moody 41 (2013)
IMHO #673827 20/11/20 05:53 PM
I had the same on my car - bolt-in crossmember first, replaced by bolt-in A-Frame f.o.c by dealer at some future service. Cracks still appeared in both places mentioned above, requiring chassis change. Suspect that these different bracing methods just moved the problem somewhere else unfortunately.
IMHO #673859 20/11/20 08:20 PM
The bolt in "A" frame does not eliminate the crack problems but may reduce them. There is more to the post 2014 chassis than just a welded in "A" frame cross brace I suspect. Although I cannot say with 100% certainty, some of the tube gauges are thicker and possibly of a different specification. As far as we are aware, there have been no cases of the detailed cracks on post 2014 specification chassis and the MMC "recall" was not applicable to post 2014 chassis cars. Sadly DVSA didn't make MMC issue a chassis crack recall. The faulty early brake pedal design remains the only official recall for the M3W. The chassis cracks were only mentioned in the information at the top of this forum section by MMC. Possibly DVSA and MMC considered the cracking of the front suspension mounts to be a non catastrophic type failure? Let's hope they are right.
If you have a pre 2014 specification chassis car, I suggest you familiarise yourself with what and where to check on the chassis and check it periodically. A scheduled dealer service is no guarantee that the chassis will not be cracked. As mentioned, the information is freely available on the MTWC website.
A bit of thread drift there Phil, sorry. I hope you find a suitable M3W.
