Topics49,908
Posts838,124
Posts: 161 |
Hi all,
Any advice on pulling outer bearing races from the hubs? The outer inner bearing came out easy. The oil seal too, then the inner bearing lifts right out. But both outer races are stuck in the hubs. Should I try and whack them out (gently of course), with a drift, or is one of those blind hole pullers is the way to go?
-Nelson ‘66 plus 4 2-seater
- Nelson
1966 Plus 4 RHD
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
I use one of these to push out evenly dont use a drift or if you damage the hubs..... You may need an attachment to the end of the rod to fit the bearing Untitledpress by Robert & Ali Davies, on Flickr
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I’d use a brass dolly that way no damage. Regards Simon
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
How bad are the bearings, bad enough to need replacing?
I run a thick bead of MIG weld carefully around the bearing track then when everything is still nice and hot, I belt them out with a large hammer and drift
Arwyn
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Nelson
If you do choose to buy a bench press you won’t believe how useful they are. Not crazy expensive, a basic one is a few hundred dollars and it’s not just bearings that they can be used for.
King pin bushes pressed in and out, all sorts of assembly work, holding small parts for drilling (how many times have you needed 3 hands?) I even used mine to bend sheet steel and metal strip. I had hear of MogBoxes coming detached so fabricated a safety clamp using the bench press.
One of those things that have you wondering how you ever managed without one.
BR Colin (Guys need ‘stuff’)
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
If I had room I would get a press. Changing front discs last year....stuck onto the hubs. A press would have made that job easier! It would double up as a fruit press too. Mmmmmmm home brewed cider.
Posts: 450 Likes: 1
Posts: 450 Likes: 1 |
This is for races which are impossible to remove any other way and it needs to be done with care and safety glasses! Run a weld round the inside of the race about middle of the width. When the weld cools the race will fall out. Bear this in mind when thinking of the stresses set up by welding chassis tubes like the M3W ones!
Posts: 161 |
Great advice all. For those that use the press, it’s not a straight shot down at the bearing. How can you push them out with a straight press?
I did manage to get them out safely with a drift. But you really must angle the thing to get good purchase on the bearing race lip.
- Nelson
1966 Plus 4 RHD
