2 members (sewin, Tony Quinn),
262
53
Posts837,962
Posts: 57 |
Just to ask a question.
I have a plus 4 when I turn the key to start it some times nothing happens and then turn it again and it fires up.
Not sure if this is normal or not.
Thanks for any info
Ian
Ian
Morgan Plus 4. 110 Anniversary Volvo S60. R Design t5 2020 70 reg
Posts: 2,583 |
Do you leave a few seconds for everything to switch on before firing up the starter motor? I get in the car, turn the key for the electrics then fasten the seatbelt & check mirrors before starting the engine. It works for me.
Posts: 192 Likes: 3
Posts: 192 Likes: 3 |
Yes I can confirm mine does that on occasions. I do normally wait a bit as Phil said so not sure if it happens when I get inpatient and don’t wait.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
I have had 2 +4’s with an immobiliser (both 2008 cars) and this was a regular issue. Someone mentioned to use the model ignition on, wait for all the whirring and clicking to stop as the car sets itself, by then the codes will be exchanged with the key transponder and the car will start.
Never had it happen again after I gave it the few seconds time to ‘set up’.
My current 2012 4/4 is the same.
BR Colin
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Another possibility could be the battery in the key. I think there are also posts from a while back about the sensors in the key and ignition failing to “speak” to each other. People have posted about the problem in the past.
Posts: 663 Likes: 14
Posts: 663 Likes: 14 |
There are no batteries in the key but there is a chip which should be detected by a transponder in the ignition switch. Sometimes it fails to work and sometimes the tiny chip falls out of the hole in the key. So best to always carry a spare key otherwise (usually in the French Alps in my experience) one can be stranded. A good key cutter these days can copy the chip and make a spare key with the correct chip in it.
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
IIRC there is a thread on here about the detector for the transponder chip being known to move. Edit - found it: DaveW Woskshop Note on Transponder Issue
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Yes, I think Dave W is the expert on curing this
