3 members (linklaw, Image, Elliot), 276 guests, and 42 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,322
Members9,215
Page 9 of 9 1 2 3 4 5 6 7 8 9
LightSpeed #676559 06/12/20 05:23 PM
O
O
You have got that right Stephen!
LightSpeed #676562 06/12/20 05:32 PM
O
O
Not wishing to add too much to the Morgan bashing, there's enough of that in another thread innocent
As its well known that the NVH was not their best bit of engineering this wont hurt.
This is the rear mount that has had a chunk machined out for belt clearance but has obviously weakened it as can be seen by the bend.
LightSpeed #676565 06/12/20 05:42 PM
I
I
Ouch. How could anyone with a conscience let that get out into the world. Are they still doing that cut out? scared
M3W Brooklands (2015)
Moody 41 (2013)
LightSpeed #676574 06/12/20 06:36 PM
This was what was on my 2019 June production M3W.
LightSpeed #676595 06/12/20 07:51 PM
Proper engineering hide
Obie #676611 06/12/20 08:42 PM
The drive belt alignment is often a bit of a compromise. You can get a straight edge between the front and rear sprockets to align them. The rear sprocket can be set to be straight in the chassis with the wheel alignment using a laser onto a target at the front of the car (details on the MTWC website). You can then check the front sprocket is aligned with that using the straight edge, although there isn't much scope to adjust the front sprocket other than choosing exactly where to secure the tube clamp mounts at the rear of the BB or elongating the holes at the front, neither ideal and only very minimal. You may have to sacrifice some of your rear wheel alignment to run the sprockets parallel.
The swing arm pivots can be adjusted to get things better as well by moving the swing arm left or right. Most seem to end up with the left side swing arm pivot almost touching the outside of the bevel box sprocket. If the belt is moving a lot from left to right on acceleration and deceleration (or reverse) then the alignment isn't great. The sprocket guides should be guides, not restraints. If the belt runs hard against any of the guides they will eventually break.
Any one for a chain drive? wink
LightSpeed #676622 06/12/20 09:07 PM
O
O
Thanks for this Ian. There is more movement than i would like when changing the direction on the belt so will check the alignment as you suggest. Can't find the article you referred to on the MTWC website, can you point me in the right direction please.
LightSpeed #676656 07/12/20 08:12 AM
O
O
Found it, didn't realise there was a members 5 speed article section i was looking in the sample article section. Wow lots of helpful stuff there!
