1 members (+8Rich),
312
90
Topics49,870
Posts837,667
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Never seen a propshaft split like that. Would take it to a specialist and have a new one built.i had one built locally when I was restoring a flat rad ,surprised how cheap it was.
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
Maybe worth a call to Simon at SiFab, who seems to know all things morgan and Aero.
David Aero S4
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Ouch. That does look like a failed seam. Good luck.
Posts: 37,435 Likes: 978
Posts: 37,435 Likes: 978 |
With that factory history Andrew it might be worth a PM to asbojohn at this place as I believe he was the first owner and a very helpful chap who gets his cars serviced at the factory and could well know the full story.
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
If you wish to experiment to see if it’s prop shaft or wheels, you could try attaching a jubilee clip around the propshaft up where the split is. The screw part of the jubilee clip will act as an eccentric weight. You could then drive it to see if any improvement with a variety of clip positions around the shaft. If you find an improvement then it points to the prop.
Posts: 141 Likes: 2
Posts: 141 Likes: 2 |
Thanks Richard, John has kindly PM'd me though he did have the factory do all his maintenance.
AnDrew G 2003 Aero S1 - past 2009 Aeromax - past 2012 +4 Supersport - past 2008 Aero S4 -past
Posts: 141 Likes: 2
Deejay, unfortunatley I'm not a hand's on person with cars so at moment reading with interest othe TM posts and waiting on a Price from Williams for a new propshaft (suspect with Morgan this may not even be a BMW oem part). Cheers
Posts: 2,433 Likes: 66
Posts: 2,433 Likes: 66 |
Andrew. If you plant the loud peddle the back of the aero will pull to the left and spin the wheels in first second and third so at least you found the problem before something serious happened. I hope once you get the service done you get to enjoy the car for what it is. Em
Gone to Porsche Part of the Furniture
Posts: 4,333 |
Shame the MOT Man didn't spot this, the test was only done days before purchase, although I don't think it comes under the MOT inspection.
With having the 2 brand new tyres fitted to the rear only a week before the sale i assumed it might be balance of wheels I will show pictures to a Propshaft refurbished here and see if it is reparable.
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I don't normally frequent this part of the forum but I've just tripped over this thread.
I wonder how long you've had this car because that split looks to me as something that started a while back and is now propagating quite badly.
I used to work in the prop shaft industry (many years ago) and I can tell you that shaft is not safe to drive.
Whatever you do, don't spin up the shaft to any significant RPM and only put the minimum torque you can use to get it on a transporter.
And don't weld up the crack. It either needs a new tube fitting of a complete new prop shaft.
I could even suggest that the car might have been sold to you in an unsafe condition. What about contacting the seller for a friendly chat.
Bob
