Morgan Aero 8
1 members (+8Rich), 313 guests, and 86 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
Page 5 of 6 1 2 3 4 5 6
Can you not trailer or tow it to the new location?
le Asbo du Bling
le Asbo du Bling
Its an auto so it can't be towed.
Slowly going green
What - not even if put in neutral?
Everyday a school day here on TM!
HB
Golf ehybrid thingy “Toadie”
Polestar 4 “Vger”
The only way to tow the Plus 8 is to remove the propshaft - the reason being that the oil pump in the gearbox would not be working although there would still be rotation of gears etc with the shaft connected. Same reason as the automatic boxes.
I don't know about any other Morgan gearbox arrangements but I would always get a flatbed recovery as opposed to risking it. Towing is not a very safe thing really unless it's over a very short distance in old bangers snowlaugh
Aaaaah.
Have been watching odd episodes of Trucking Hell recently and that matches why they remove the “half shaft” on the lorries before towing. ie it’s a gear box thing rather than anything else...wonder if same applies to electric cars (thread drift apology insert here)
HB
Polestar 4 “Vger”
Would probably charge an EV's battery! smile
drewg Offline OP
Well at long last my S4 is booked in at the MMC Factory to remove the propshaft and send make to the original manufacturers to refurbish. Hopefully then will be able to enjoyin time for when Boris relaxes some of the Covid restrictions so that we all may be able to enjoy a bit more freedom driving somewhere....anywhere will do!!
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2012 +4 Supersport - past
2008 Aero S4 -past
Good luck with the repairs.
drewg Offline OP
At long last got my S4 back from the factory all serviced and importantly the prop shaft sorted out (GKN the OEM supplier reconditioned it though did take them 6 weeks which was understandable given that they have made a lot of redundancies). Have been able to drive the car as was meant to be driven. happy3
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2008 Aero S4 -past
Glad to see you have her back, looking resplendent and sounding wonderful I'm sure, enjoy your long awaited miles.
