7 members (Image, JohnHarris, Mats, Montegue, stumog, Gordon D, John V6),
413
85
Topics49,848
Posts837,408
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Dullan .... You're right, it's a not uncommon thing (tho through years of Swedish, French, American, Italian and British cars I've never owned one with that feature actually fitted ).
Deejay .... that sounds extremely plausible .... I'll go with that and consider my curiosity satisfied!!
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
On VWs leaving the inidicator on used to turn on the sidelights when the key was removed.
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Greetings All Casually scouting through my wiring diagram and I came upon the item circled in red . I can't seem to find a corresponding item on the car and it's not clear from the diagram if it's a switch, part of another switch or a relay (with the operating circuit 'simplified out') I can see what it does ..... a changeover that gives you side/tail lights or just RH side/tail and drops an earth on the coil thereby disabling the ignition. Is it some sort of Parking Mode that leaves your 'outside' lights lit? .... still don't see the need for the related earthed coil part though? There will probably be some simple explanation I'm missing that everyone knows but me!  ![[Linked Image]](https://www.tm-img.com/images/2020/12/20/20201220_172906.jpg) Cheers K The changeover switch in park mode would allow the coil earth to inhibit engine starting for security and as a reminder as suggested. I'm guessing it would be in a less than obvious location.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Greetings All Casually scouting through my wiring diagram and I came upon the item circled in red . I can't seem to find a corresponding item on the car and it's not clear from the diagram if it's a switch, part of another switch or a relay (with the operating circuit 'simplified out') I can see what it does ..... a changeover that gives you side/tail lights or just RH side/tail and drops an earth on the coil thereby disabling the ignition. Is it some sort of Parking Mode that leaves your 'outside' lights lit? .... still don't see the need for the related earthed coil part though? There will probably be some simple explanation I'm missing that everyone knows but me!  ![[Linked Image]](https://www.tm-img.com/images/2020/12/20/20201220_172906.jpg) Cheers K I reckon that the lockdown is getting to you when you start reading wiring diagrams!
At least they follow logic .... unlike reading the newspapers!  Ex electronics tech, so comfort reading for me ..... easy working out what the switch did ..... WHY it was put there is another thing altogether..... messy Human stuff and far less obvious  K
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
K, my old 1974 +8 had a switch that cut out the ignition on the dash. I'm afraid I can't remember (it was 1980) if it did have a light image on it, but it didn't turn on any light when operated. I turned the switch around, so it wasn't obvious when operated, so a useful immobiliser at the time.
David Aero S4
Posts: 153 Likes: 1
Posts: 153 Likes: 1 |
after spending way too much time on wiring diagrams the last couple days I believe to understand the circuit now: Maybe an owner of an older Morgan with a dashboad like this one below can confirm that the switch labelled "P" was the "park switch" ![[Linked Image]](https://www.conceptcarz.com/images/Morgan/61-Morgan-Plus4-DV-17-RMA_i04.jpg) As you can see from the diagram the light switch was feed from the Anmeter (brown-white (NW) cable) --> to the light switch --> via a fuse to the parkswitch. If there is no key in the ignition - no power would go to the lights. Therefore, the park switch had a second power feed via the white-black cable from the coil - which in turn is feed through the ballast resistor with a white-yellow cable from the starter solenoid battery port. Based on the information and pictures from John Worrall's & Liz Turner's book it can be assumed that with the introduction of the 1969 Morgan 4/4 the black leather dashboard with the black switches also also found in the Mini and other british cars - the park switch was removed. My 1984 Morgan has exactly this light switch. It is a 3-way switch and connect via a brown cable. With this the park light can be switched on (will power red-green cable to fuse and from there on side & rear lamps). The second position of the switch will also power the blue cable (going to the flasher switch). I am quite certain that the Morgan factory made changes to the wiring over the years without documenting this in the diagrams. The park switch is a good example. Regards Tim
My Land Rover has an identical shape switch although black. It switches off the "P" for panel lights when not required, after turning on lights. This was quite common in early cars with dynamo charging as every milliamp counted
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
My Land Rover has an identical shape switch although black. It switches off the "P" for panel lights when not required, after turning on lights. This was quite common in early cars with dynamo charging as every milliamp counted  I had a couple of old MOD Land Rovers - they also had the 'convoy' light - it would turn all the lights off, bar a small low powered bulb above the rear diff (which was painted white) for night time stealth operations.....
Posts: 153 Likes: 1
just to make sure - are we talking about the same switch? ![[Linked Image]](https://fixingc6622.files.wordpress.com/2021/01/parkswitch.png)
