2 members (TeddyAds, vincentvg), 183 guests, and 85 robots.
Topics49,848
Posts837,396
DazMog, The Impaler, tlchzj79
#679040 20/12/20 05:46 PM
Image Offline OP
Greetings All
Casually scouting through my wiring diagram and I came upon the item circled in red .
I can't seem to find a corresponding item on the car and it's not clear from the diagram if it's a switch, part of another switch or a relay (with the operating circuit 'simplified out')
I can see what it does ..... a changeover that gives you side/tail lights or just RH side/tail and drops an earth on the coil thereby disabling the ignition.
Is it some sort of Parking Mode that leaves your 'outside' lights lit? .... still don't see the need for the related earthed coil part though?
There will probably be some simple explanation I'm missing that everyone knows but me! smile
Cheers
Image #679042 20/12/20 05:52 PM
TBM Offline
|In the Brooklands Guide it's labelled as the Parking Switch
Image #679043 20/12/20 05:57 PM
Image Offline OP
Thanks .... thought it was something along those lines ..... the diagram is for up to '73 and mine's a '75 so maybe never had one or it's been removed by a previous owner .... seems slightly overkill to short the coil to earth as a parking aid ..... does it say where the switch might have been situated ?(if out of the way I suppose it could have been a primitive immobiliser)
Image #679044 20/12/20 06:01 PM
TBM Offline
No, typically there is no other reference to it in the entire guide! I don't recall seeing it on mine. I don't think I have a 'park setting' on the ignition key, and certainly don't have a switch. It may be a +8 anomaly - I found this on eBay +8 Park Switch
Image #679045 20/12/20 06:02 PM
Ray Offline
Proberly a throw back to when cars had to leave a light on when parked on the street overnight.
Image #679046 20/12/20 06:08 PM
TBM Offline
On mine, you can turn the sidelights on without the key in the ignition so maybe that superceeded the additional parking light switch?
Image #679047 20/12/20 06:11 PM
TBM Offline
It's still law to use parking lights in certain situations
Quote
According to the Highway Code (section 249) all vehicles are required to display parking lights when parked on a road or a lay-by with a speed limit greater than 30mph.
The Highway Code also advises motorists to avoid parking on the road in fog unless it’s unavoidable, and to leave parking lights on in this situation.
Image #679049 20/12/20 06:13 PM
Image Offline OP
Thanks for the info .... there were all sorts of oddities over the years (I had a GT6 with a circuit that dimmed/brightened your tailights depending if it was day or night .... all very impressive but soon fell over and got ignored ... the '70s wasn't a happy period for mixing electronics and motor cars in general) Sounds like a period quirk and related to the +8 ..... the switch looks to be made to be on the dash in full view so the 'immobiliser' idea seems unlikely ..... any takers on explaining the ignition cutout function??
Image #679071 20/12/20 09:02 PM
Prevents you driving off with parking lights left on?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Image #679080 20/12/20 11:27 PM
You can find quite a few threads covering modern Mercedes, BMW and other German makes that have one-side-at-a-time parking lights as a standard option. But I can say that this is not a modern option at all, and while I don't think it was ever common on American cars - big,wide streets and all - it was certainly a feature in '60s and '70s German cars. Perhaps this was an option available for Morgans sent to Germany? Pre-wired/dealer installed? Just a guess. Saw interesting photos on Google of new MB's with two switches to select either left-side or right-side parking lamps.
