11 members (jejemek, IcePack, Baristas, vincentvg, aerotaff, Image, Vansrv6, Alan Patterson, Ritchie B, Ncik P, BLUE+4), 323 guests, and 78 robots.
+8Rich 86
Topics49,851
Posts837,443
#679653 24/12/20 03:09 PM
chrivi Offline OP
Hello,
I have found the following. On the rear axle, when you move the wheel axially back and forth you notice a gap of a few millimeters. Is the problem the wheel bearing, or the rear axle? If so, can it be adjusted?
Thanks for your comments and Merry Christmas
Christoph
Christoph
Roadster 3.7 - 2014
silver matt
Ray Offline
Check the U bolt nuts are tight On some cars they have habit of loosening
You do not say exactly where the “gap” is.
Bear in mind, when you move the wheel axially, there will always be some “slop” or backlash in the differential gears. This is essential to ensure clearance as the gears heat up and expand. It is usually set by applying shims to the gear mechanism. Unless it is giving a problem, I would leave well alone.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
chrivi Offline OP
It feels like the play is in the wheel bearing. The wheel can be clearly moved back and forth. Loose U-bolts are not the cause though
Christoph
Roadster 3.7 - 2014
silver matt
Both sides or one side only?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
It sounds like you're describing end float in the diff, there should be some. How many miles has the car done ?
Logic would suggest that if you grip the wheel by the tyre and rock it left/right or top/bottom and there's play, then it's the bearing .... if you pull the wheel in and out evenly and there's play then it's end float in the diff (tho if the bearing is really slack you'll feel both)
chrivi Offline OP
The car has 32000km. On the left side it is more, right less.
I can pull the wheel in and out, so it can be the end float of the diff. How this can be solved?
Christoph
Roadster 3.7 - 2014
silver matt
As long as it pulls in and out without excessive 'rocking' then it does sound like diff end float .... someone more knowledgeable than me will tell you if the amount you have is more than normal.
chrivi Offline OP
Thanks for your comments. I let it check
Christoph
Roadster 3.7 - 2014
silver matt
