1 members (Saxonian), 242 guests, and 39 robots.
+8Rich 63
Adam12 61
John V6 55
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,300
Members9,215
Good idea Dave. Would that be the black plastic spiral strip that binds cables into a loom?
Much more substantial than that, tend to be used on rubber un-braided hoses
Look at "brake pipe spiral protector" google images, there are loads to chose from.
Thanks to you both. Looking towards securing slippery material to brake reaction bar or maybe both.
If its empty I would use DOT 5 on a 3.7 roadster as mine tends to boil on high speed European roads. DOT 5 has a higher boiling point.
Err, be very careful, correct in part - dot 3, dot 4 and dot 5.1 are compatible as they are glycol based and have increasing temperature ratings. Dot 5 is silicone based, entirely different and not compatible with other fluids.
If you are going to substitute dot 5 for 3 or 4 you may well be advised to either wash the system out or replace the rubbers in both cylinders.
Hi Chaps, jumping on this , please can someone explain how to bleed the clutch on the 3.7 roadster (2016). I can't find a bleed nipple on the bell housing and I understand there is this concept of suction bleeding that I have never heard of - and there are some videos on you tube that help !! Sorry to sound thick
It's a concentric slave cyl, sort of combined with the release bearing & unfortunately does not have a bleed nipple facility
I (sort of) changed my fluid by syringing out the reservoir & topping back up with new
Jon,
how does any air get out then? Is that why the fluid reservoir sits so high wrt the piston?
2025 MG ZS EV aka Trigger
Apparently they self clear any air when pumped, but I prefer a traditional nipple innocent
I made sure not to empty the reservoir too low down
Merry Christmas all. My clutch feels spongy, my cotter pin/ linkages all seem fine, and my clutch fluid levels seem ok. Gear changes are fine , but I can feel this is an accident waiting to happen. There doesn't seem to be brake fluid on the clutch piston assembly (where it comes through the bulkhead) which makes me think the seals on the master cylinder are a bit suspect. Any ideas chaps?? My instinct would be to bleed it - but it sounds like that's not on. Any ideas???
