2 members (sewin, KLASG),
348
Topics49,838
Posts837,294
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Gosh, that is stunning, Andrew!
Posts: 141 Likes: 2
Posts: 141 Likes: 2 |
Thanks, seems like you also like unusual / individual colours (I'm still a little unsure of the colour but Aero's are individual so why not an indivual colour  ). Had it at Williams on Friday to try sort a vibration issue. Changed 1 buckled wheel which helped a bit but seems there is a split in the propshaft which may be the root cause  .
AnDrew G 2003 Aero S1 - past 2009 Aeromax - past 2012 +4 Supersport - past 2008 Aero S4 -past
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
Looks wonderful Andrew, hope you get that vibration sorted asap.
David Aero S4
Posts: 1,646 Likes: 1
Posts: 1,646 Likes: 1 |
Thanks, seems like you also like unusual / individual colours (I'm still a little unsure of the colour but Aero's are individual so why not an indivual colour  ). Had it at Williams on Friday to try sort a vibration issue. Changed 1 buckled wheel which helped a bit but seems there is a split in the propshaft which may be the root cause  . Definitely check the propshaft as it will give a slight vibration at some speeds if loose. Only vibrations at some speeds but not all. The next think you know....Bang!! Worst sounding thing ever, sounds like blown gearbox and sparks everywhere. Gearbox mounting sheared off. The fix was either buy a new gearbox £8,000 plus vat for parts and probably couple more thousand or so for labour or perhaps matching gearbox from scrapped BMW, remove innards, replace with the Aero innards making use of the gearbox casing and all good to go. Don't ask how I know. Fortunately, there are a lot of matching auto -boxes in scrapped bmw's!
Aero 8 GTN. #10
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
 Struggling to upload photo's but have a couple on TM Image Library ![[Linked Image]](https://www.tm-img.com/images/2020/12/06/20201204_142027.md.jpg) [img]http://<img src="https://www.tm-img.com/images/2020/12/06/20201204_141915.jpg" alt="20201204_141915.jpg" border="0" />[/img] ![[Linked Image]](https://www.tm-img.com/images/2020/12/06/20201204_141915.md.jpg) Looks as lovely as I remember! Great smart interior as well.  Thanks, seems like you also like unusual / individual colours (I'm still a little unsure of the colour but Aero's are individual so why not an indivual colour  ). Had it at Williams on Friday to try sort a vibration issue. Changed 1 buckled wheel which helped a bit but seems there is a split in the propshaft which may be the root cause  . Definitely check the propshaft as it will give a slight vibration at some speeds if loose. Only vibrations at some speeds but not all. The next think you know....Bang!! Worst sounding thing ever, sounds like blown gearbox and sparks everywhere. Gearbox mounting sheared off. The fix was either buy a new gearbox £8,000 plus vat for parts and probably couple more thousand or so for labour or perhaps matching gearbox from scrapped BMW, remove innards, replace with the Aero innards making use of the gearbox casing and all good to go. Don't ask how I know. Fortunately, there are a lot of matching auto -boxes in scrapped bmw's! Jeez that sounds like a heck of a job.
Aero 8 GTN #11
Posts: 11,523 Likes: 312
Posts: 11,523 Likes: 312 |
I had a few bolts on the S2 prop swapped at the last service. Not a huge deal.
Gone to Porsche Part of the Furniture
Posts: 4,333 |
i suppose i better change my Avatar
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
i suppose i better change my Avatar How about a Holts rattlecan from 1982
Posts: 141 Likes: 2
 Thanks Shooter, think may start a new thread if I can upload a photo of the split innthe propshaft see if others concur that this may be the issue.  I think logic says will be so will need a specialist to replace which will involve dropping the suspension. Car needs a service which I knew about. Cheers
Posts: 263 |
no James ... no heated seats but i did drive to scotland once in full sailing waterproofs. The trackday at knockhill was worth it though!!!
Aero-Ian
Aero 8 Series 1 Defender 90 BMW 330d M Touring
