Morgan Aero 8
2 members (Julian BB, Marmota), 318 guests, and 44 robots.
+8Rich 93
Posts837,277
Page 5 of 6 1 2 3 4 5 6
Formerly known as Aldermog
Gosh, that is stunning, Andrew!
Thanks, seems like you also like unusual / individual colours (I'm still a little unsure of the colour but Aero's are individual so why not an indivual colour happy3). Had it at Williams on Friday to try sort a vibration issue. Changed 1 buckled wheel which helped a bit but seems there is a split in the propshaft which may be the root cause drive stars.
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2012 +4 Supersport - past
2008 Aero S4 -past
Looks wonderful Andrew, hope you get that vibration sorted asap.
David
Aero S4
Definitely check the propshaft as it will give a slight vibration at some speeds if loose. Only vibrations at some speeds but not all. The next think you know....Bang!! Worst sounding thing ever, sounds like blown gearbox and sparks everywhere. Gearbox mounting sheared off. The fix was either buy a new gearbox £8,000 plus vat for parts and probably couple more thousand or so for labour or perhaps matching gearbox from scrapped BMW, remove innards, replace with the Aero innards making use of the gearbox casing and all good to go. Don't ask how I know. Fortunately, there are a lot of matching auto -boxes in scrapped bmw's!
Aero 8 GTN. #10
surrender Struggling to upload photo's but have a couple on TM Image Library [Linked Image]
[img]http://<img src="https://www.tm-img.com/images/2020/12/06/20201204_141915.jpg" alt="20201204_141915.jpg" border="0" />[/img]
Looks as lovely as I remember! Great smart interior as well. thumbs
Jeez that sounds like a heck of a job. shocked2 pantsdown
Aero 8 GTN #11
Smile, it confuses them
I had a few bolts on the S2 prop swapped at the last service. Not a huge deal.
Gone to Porsche
Gone to Porsche
i suppose i better change my Avatar
How about a Holts rattlecan from 1982 laugh
confused2 Thanks Shooter, think may start a new thread if I can upload a photo of the split innthe propshaft see if others concur that this may be the issue. idea I think logic says will be so will need a specialist to replace which will involve dropping the suspension. Car needs a service which I knew about.
Cheers
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2008 Aero S4 -past
no James ... no heated seats but i did drive to scotland once in full sailing waterproofs. The trackday at knockhill was worth it though!!!
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
