8 members (Vansrv6, Craig Jezz, vbalddave, bmgermany, cerealsurfer, JMcL, sewin, +8Rich), 109 guests, and 28 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,100
#680710 31/12/20 11:36 AM
tommog Offline OP
Found this on German Morganpost. Maybe you ยด re interested!
https://fixingc6622.wordpress.com/
2018 +4, persian blue
TBM Offline
That's TimB - he's a TM member:)
he's been very busy.
and today I am completely lost while trying to figure out how the new AutoSparks wiring loom, the wiring diagramm in the owners handbook and the previous wiring should map. BS-AU7 headache galore. smile
If anybody has a correct wiring plan for the Morgan 4/4 with Ford CVH engine - please let me know.
TBM Offline
Have you tried GoMog?
Electical stuff
This is the one I referred to when I had a CVH engined 4/4. Sadly, I cannot remember where I got it from.
Please double check a few things before you rely on it.
Costock, UK
Disco 5
Hi TBm, Hi Paul,
The plan on the Gomog page and the plan above (also printed in the drivers handbook) are all the same.
But there are a number of differences between the plan and what is actually in the loom (the one installed from the factory)
E.g. The ballast resistor is missing. There is a white and white-black cable to the ignition coil. This in turn has a black and green-black cable running to the distributior.
Alternator, Starter and Ignition also slightly vary from the plan above.
There is a Red-Yellow cable (Bs-Au7: fog lights) in the loom - not shown in the plan.
The park-switch (also discussed in another conversation here on this forum) is also difficult to find. My Morgan my father installed a MK dashboard with different switches. This makes it even harder to find this in the old loom.
The Autosparks loom (which does not have any documentation and is supposed Identical) has a number of smaller differences. Just takes time to figure it out.
TBM Offline
Athough on several wiring diagrams, my '72 certainly didn't have a park switch. It may have been a regional variation.
If you have a non ballast coil you won't need the ballast resistor and associated 'bypass' wire for starting.
Might be worth looking at a much later date wiring diagram and doing a comparison?
That was a very good suggestion. Didn't think about it yesterday. The next plan on GoMog is the 1988-1989 plan for all Morgan cars. This looks much closer to the one installed on my car. https://www.gomog.com/allmorgan/wiring88&89.jpg
Back to work bench... ๐Ÿ˜€๐Ÿ‘
TBM Offline
Good luck!
