Topics49,918
Posts838,238
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
I have got front fog beamers [i][/i]and a rear fog light fitted. The push button switches are confusing as there is no difference between front and rear. As I barely use them I always forget which switch is for which light. I would like to turn the buttons by 90° south and north so it would be obvious which one is heading front or rear. Is this a simple operation or do I have to dismantle the whole dashboard? ![[Linked Image]](https://up.picr.de/40223375pv.jpeg)
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
I wouldn't say it was a simple job, when I had my indicator problem and seen behind the panel the switches are hard soldered onto a PCB. Depends on the age of the car I guess. Mine is 2014.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Thank you, Gordon. Most likely we have a very similar dashboard - 2011 build
Maybe I better put an outside marker to the dashboard
Posts: 8,705 Likes: 416
Posts: 8,705 Likes: 416 |
Hannes international convention has symbols pointing to right to indicate rear and to the left, front.
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
You can just pull them out from the front with the EAO tool.. You can even print your own new graphics if you want.... ![[Linked Image]](https://dl.dropboxusercontent.com/s/0my67zzuqnzfud9/EOA%20tool.jpg)
Roger 2011 Plus 4
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
Clever stuff that Roger, I've always popped them apart 'on the bench' out of the dash
Thank you, Roger! That's exactly what I was looking for.
You are welcome Hannes. It’s a useful tool to have if only for gaining access to the lamps.
Roger 2011 Plus 4
