7 members (Haggispeed, John Winn, jbk, Mogdavid, Ricosan, DaveW, Ian Wegg), 314 guests, and 80 robots.
+8Rich 103
John V6 63
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,247
MossyfromNZ
#680874 01/01/21 12:32 PM
I have got front fog beamers [i][/i]and a rear fog light fitted.
The push button switches are confusing as there is no difference between front and rear.
As I barely use them I always forget which switch is for which light.
I would like to turn the buttons by 90° south and north so it would be obvious which one is heading front or rear.
Is this a simple operation or do I have to dismantle the whole dashboard?
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
I wouldn't say it was a simple job, when I had my indicator problem and seen behind the panel the switches are hard soldered onto a PCB. Depends on the age of the car I guess. Mine is 2014.
Gordon Duguid
Thank you, Gordon.
Most likely we have a very similar dashboard - 2011 build
Maybe I better put an outside marker to the dashboard
Hannes
Hannes international convention has symbols pointing to right to indicate rear and to the left, front.
Rog Offline
You can just pull them out from the front with the EAO tool.. You can even print your own new graphics if you want....
Roger
Clever stuff that Roger, I've always popped them apart 'on the bench' out of the dash
Thank you, Roger!
That's exactly what I was looking for. happy3
Hannes
Rog Offline
You are welcome Hannes.
It’s a useful tool to have if only for gaining access to the lamps.
Roger
