7 members (Image, andymog1, DJC, John V6, Simon, TalkMorgan, IcePack), 252 guests, and 27 robots.
+8Rich 99
John V6 57
Topics49,908
Posts838,119
Hi,
A new noise has been located to the pulley on the sepentine belt tensioner for the water pump and generator.
I am however struggling to find a replacement part. Is this pulley the same as on the opposite side of the engine?
Can this pulley be bought separately or do I need to buy a complete new tensioner?
Hints and tips for article number and the like will be most welcome.
4/4 2 seater 2001 model
I renewed mine recently (2002 4/4, blacktop 1.8 Zetec) when I changed everything at the front end including the cam belt and pulleys, aux drive belt and pulleys, water pump and alternator the aux drive belt tensioner was ok so just did the pulley on it, maker was Ruhl with part number “ten 10036”.
Cam belt and pulleys came from Melvyn Rutter, aux belt and everything else came from a local motor factors after I gave them the old ones as a sample. The big pulley where there would normally be a hydraulic pump for power steering is a steel one and the bearing can be replaced in this which is what I did.
Regards
Simon
2002 4/4
2021 Audi A1 sport
I also renewed mine recently (2002 4/4, blacktop 1.8 Zetec). The pulley was Gates T36199, and accessory belt was Gates micro-v 6PK1903. The original accessory belt was Gates micro-v 68437 but this seems to have been superseded.
1994 +8, BMW Calypso Red.
How do you open the boot?
Guten and Calypso, thank you for your advice.
