6 members (howard, PaulJ, IcePack, Alan Patterson, AlyMatt, How), 303 guests, and 84 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Image #679084 21/12/20 12:09 AM
Image Offline OP
Dullan .... You're right, it's a not uncommon thing (tho through years of Swedish, French, American, Italian and British cars I've never owned one with that feature actually fitted ).
Deejay .... that sounds extremely plausible .... I'll go with that and consider my curiosity satisfied!!
Image #679093 21/12/20 08:04 AM
On VWs leaving the inidicator on used to turn on the sidelights when the key was removed.
Image #679096 21/12/20 08:22 AM
Originally Posted by Image
Greetings All
Casually scouting through my wiring diagram and I came upon the item circled in red .
I can't seem to find a corresponding item on the car and it's not clear from the diagram if it's a switch, part of another switch or a relay (with the operating circuit 'simplified out')
I can see what it does ..... a changeover that gives you side/tail lights or just RH side/tail and drops an earth on the coil thereby disabling the ignition.
Is it some sort of Parking Mode that leaves your 'outside' lights lit? .... still don't see the need for the related earthed coil part though?
There will probably be some simple explanation I'm missing that everyone knows but me! smile
Cheers
The changeover switch in park mode would allow the coil earth to inhibit engine starting for security and as a reminder as suggested. I'm guessing it would be in a less than obvious location.
Image #679116 21/12/20 10:22 AM
Online Happy
Greetings All
Cheers
I reckon that the lockdown is getting to you when you start reading wiring diagrams! rtm
Image #679119 21/12/20 10:40 AM
Image Offline OP
At least they follow logic .... unlike reading the newspapers! smile
Ex electronics tech, so comfort reading for me ..... easy working out what the switch did ..... WHY it was put there is another thing altogether..... messy Human stuff and far less obvious thinking
Image #679290 22/12/20 04:33 PM
K, my old 1974 +8 had a switch that cut out the ignition on the dash. I'm afraid I can't remember (it was 1980) if it did have a light image on it, but it didn't turn on any light when operated. I turned the switch around, so it wasn't obvious when operated, so a useful immobiliser at the time.
David
Aero S4
Image #682283 10/01/21 12:07 AM
after spending way too much time on wiring diagrams the last couple days I believe to understand the circuit now:
Maybe an owner of an older Morgan with a dashboad like this one below can confirm that the switch labelled "P" was the "park switch"
As you can see from the diagram the light switch was feed from the Anmeter (brown-white (NW) cable) --> to the light switch --> via a fuse to the parkswitch.
If there is no key in the ignition - no power would go to the lights. Therefore, the park switch had a second power feed via the white-black cable from the coil - which in turn is feed through the ballast resistor
with a white-yellow cable from the starter solenoid battery port.
Based on the information and pictures from John Worrall's & Liz Turner's book it can be assumed that with the introduction of the 1969 Morgan 4/4 the black leather dashboard with the black switches also also found in the Mini and other british cars - the park switch was removed.
My 1984 Morgan has exactly this light switch. It is a 3-way switch and connect via a brown cable. With this the park light can be switched on (will power red-green cable to fuse and from there on side & rear lamps). The second position of the switch will also power the blue cable (going to the flasher switch).
I am quite certain that the Morgan factory made changes to the wiring over the years without documenting this in the diagrams. The park switch is a good example.
Regards
Tim
Image #682301 10/01/21 09:14 AM
My Land Rover has an identical shape switch although black. It switches off the "P" for panel lights when not required, after turning on lights. This was quite common in early cars with dynamo charging as every milliamp counted wink
RichardV6 #682305 10/01/21 09:27 AM
TBM Offline
I had a couple of old MOD Land Rovers - they also had the 'convoy' light - it would turn all the lights off, bar a small low powered bulb above the rear diff (which was painted white) for night time stealth operations.....
Image #682324 10/01/21 10:38 AM
just to make sure - are we talking about the same switch?
